4x4 Related Groups => Tech Talk => Topic started by: Moezer on January 23, 2014, 01:21:43 PM
Title: really low on oil??
Post by: Moezer on January 23, 2014, 01:21:43 PM
hey guys, so I changed the oil on my jeep before the winter storm hit, my next oil change should be at 300k  but since the snow storm has hit I have noticed that the ticking I get from the engine has increased I didn't mind it because it was only loud on cold starts, fast forward to last night im coming home from work and I noticed that my oil pressure is going down in 3d gear, I shifted to 4 and it started to go up again then started to go down, I put it in 5th and it went up again.
Since we are having warmer weather now I have noticed that the jeep is dripping oil again, not a lot with in 3 days there was about 2 inch wide oil spill, never though nothing of it since my rear main seal has been leaky for 3 years lol.
I come to check on the oil today after taking my dog to the park to find I have NONE only the tip of the dip stick has some oil on it , I added oil to it but it took about 4 liters....  I still have about 5000 kms to drive before the next oil change, what has went wrong here? I doubt its leaking out of the rear main seal this much as I just noticed it 3 days ago
im running 5w30 oil full synthetic
any ideas ? thanks
Title: Re: really low on oil??
Post by: JackstandJohnny on January 23, 2014, 01:29:04 PM
is it blowing blue at all?
last time i had a 4L that blew through oil that fast it was all going through the valve seals/guides in the head.  i was going through a litre per fill up.
the head was so bad i just swapped the motor instead of rebuilding it.
no clue if its similar for you but that was mine.  i suggest it because for you to actually burn that much oil due to bad piston rings you would be smoking people out at red lights.
Post by: Moezer on January 23, 2014, 02:01:09 PM
nope not blue smoke its not burning oil at all, it smokes white but that's because of the cold...
Post by: Vinman on January 23, 2014, 02:53:44 PM
Apparently synthetic doesn't burn near as much blue as conventional oil.
Post by: morerpmfred on January 23, 2014, 03:25:52 PM
Ccv system could be plugged up solid like mine. Air pressure inside the motor pushes oil out all the seals and into the air intake.
Title: Re:
Post by: BUKI on January 23, 2014, 08:27:47 PM
Did you say 300,000 kms. I think 5w30 even syn might be a little light. Next oc try good ol rotella 15w40. A jeep should have no issues cranking with that at -30. A diesel oil has more cleaning "thingys" and holding "Thingys". Its worth a try. And much cheaper than refilling with syn.
Sent from my Nexus 5 using Tapatalk
Post by: w squared on January 23, 2014, 08:40:16 PM
zinc
Post by: JENSSEN on January 23, 2014, 10:15:26 PM
Rotella + Lucas = :)
Title: Re:
Post by: Moezer on January 24, 2014, 02:48:26 AM
this stuff?
http://www.walmart.com/ip/Shell-Rotella-T-15W40-Motor-Oil-1-Gal/14958327
I have never had this problem before that's why its annoying me
Post by: Spinalguy on January 24, 2014, 12:18:56 PM
this stuff?
Yes.
Post by: cLAY on January 24, 2014, 07:48:24 PM
That's good oil and I run it lots of the fleet equipment that I maintain, but only in the summer
In the winter I change everything over to something lighter, 10w30 or even 0w30 synthetic. That 15w40 gets pretty thick at anything below -20c, especially when it's got some miles on it and not brand new anymore.
Title: Re: Re: Re: really low on oil??
Post by: BUKI on January 24, 2014, 08:46:16 PM
I think you may be onto something. I haven't changed my oil in 9-10 months. IIRC I used the rest of my 5-40 syn rottella t6. So I bet its a mix 50-50. But still 10-30 should crank just fine. Its what the jeep was meant to have in it. And guess what rotella conventional comes in 10-30. I trust shell. You can Google rotella+jeep+Bob is the oil guy. And everyone says the same thing. DO IT. Oh PS the best place to get the 10w30 is at PA.
Post by: BUKI on January 24, 2014, 08:51:58 PM
Oh my shyhat. Remind me to never buy a car from you;);). How do you get it to turn over??  That combo will NEVER burn oil. NOW THAT BE SOME THICK $#!+.
Post by: Bnine on February 06, 2014, 08:57:04 AM
zinc
No zinc in rotella either. They pulled it 5 or 6 years ago. Although it was the last oil to contain significant amounts of the zinc base lube.
Post by: w squared on February 06, 2014, 11:58:56 AM
I was just being an @ssh@t and referring to the thread about zinc in oil and belt dressing. My bad.
