4x4 Related Groups => Tech Talk => Topic started by: Strongbad on July 16, 2015, 04:25:49 PM
Hoping you fine folks might have some insight on this topic.
Have a 97 4.0 TJ. Want to put on a banks Sidewinder turbo, say's it only works with 1999 + TJ's due to the PCM.
Is it just as simple as pulling out the PCM from a 99 and throwing it in my 97 and flashing it ?
Thanks everyone !!
M
I would research what differentiates the 99 pcm from the earlier years. I doubt it is as simple as plug and play...the harnesses not matching may be your first issue. Good luck, wish I could help more!
you might have issues with the cluster. other than that.. My tj was a mix of alot of things.. but didnt have much issues other than the cluster
Its going to depend on sensors and injectors. You will need to research which ones remained the same, and which ones changed.
Really appreciate your help guys !
looks like it would be more trouble than it's worth.
may as well wait till the 4.0 gets tired, and shove a 350 in it.
