4x4 Related Groups => Tech Talk => Topic started by: scott slade on September 22, 2015, 03:58:16 PM
Title: 05 LJ Led turn signal flasher.
Post by: scott slade on September 22, 2015, 03:58:16 PM
Installed Led tail lights on the 05 LJ. Love em... will change front soon too. Turn signal is obviously doing the "hyper flash".  Is there a flasher relay ( 5 pin?) That will put the turn signals back to normal.?..  Who sells it.?   Looking for plug and play...
Title: Re: 05 LJ Led turn signal flasher.
Post by: CatSplat on September 23, 2015, 11:21:52 AM
You have a late TJ/LJ so you need a GCD-TJ0106 flasher (http://vh10.nethosting.com/~goldcst1/cart/index.php?main_page=product_info&products_id=15&zenid=cba13522c8ab104a92a1eb229d212b26) for LED tails.
Post by: scott slade on September 24, 2015, 01:29:39 PM
Yup... That's the part... Not sold in Canada.  It's a custom made item out of Oxnard California.  "Off Road" use only.   About $50.00  by the time it gets here....
Post by: CatSplat on September 24, 2015, 04:19:11 PM
Yeah sadly it ain't cheap, but there's not much else you can do if you want your LEDs to work normally, as far as plug-and-play goes. Some guys have modified the stock module with a Radio Shack part and some wire, but there have been reports of that mod causing battery drain while parked.
Post by: Immortal on September 24, 2015, 07:39:11 PM
What about the "heavy duty" flasher? That worked like a charm in my SJ
Post by: scott slade on September 24, 2015, 08:03:04 PM
The "Radio Shack " mod seemed too scary,  also heard of fires.  I know the pre 2001 TJ led specific flasher works in the 05 but turn signals can stay on without the key in...  so yup... $50.00 for OE function.   But I love my lights...
Post by: matthillhouse on November 17, 2015, 09:11:47 AM
Try bringing your flasher into auto value to look for a replacement. I modified my older TJ flasher, but when that crap the bed, I went to go find another one. It wasn't listed under TJ, but it was a heavy duty trailer flasher, exact same pins, and it was plug and play without having to be modified to prevent fast flash. And it was like 17 bucks.
Post by: AV.NINE on November 17, 2015, 09:21:21 AM
I had purchased the LED flasher at Napa for my 02. They had it in stock.
Post by: scott slade on November 18, 2015, 11:11:50 PM
Thanks guys, my last post on this was late September.  Ordered the modified one from California.  Works great. The 05/06 TJ's were quite unique in a lot of strange ways. ...
