4x4 Related Groups => Tech Talk => Topic started by: Phin11 on November 22, 2015, 06:56:30 PM
I have a 1992 2 Dr jeep xj . Both of the front seats are sagging back . I bought it this way ,but it is slowly getting worse . Has anyone here swap seats from anything used from pick and pull etc ? Any after market companies make adapters brackets ? Or welded in some flat bar and made adapters ? The earlier jeeps I think 84-94 are different than 96-01 (they have a collision beam the seat mounts to.
I've swapped in various different seats from ZJ's into XJ's. The seats themselves just require being unbolted from their ZJ brackets, and attached to your XJ brackets (bolt holes are in the same locations). Its a very simple mod, easy to do.
i dont think the bracket will bolt up to zj seats . My brackets are curved . like in this diagram . I was given some zj non power seats might have to find differant brackets.
http://www.jeepforum.com/forum/f53/xj-seats-mj-only-if-youre-short-242591/
I put a set of rugged ridge seats in my 01 XJ. Came with bracket. Check their site and corbeau site. They should have bracket or picture to give you a idea of what's needed.
Your seats are for the vertically challenged though ;)
Sent from my D6603 using Tapatalk
