Trading Post => Jeep Stuff For Sale => Topic started by: Ddub1973 on May 18, 2016, 08:49:39 PM
Title: Anyone with a Rubicon looking to go to 4.56 gears?
Post by: Ddub1973 on May 18, 2016, 08:49:39 PM
So here is what I am thinking about doing....
I have a 2013 JKUR and I had 4.56 gears installed by 4 Wheel Parts in 2014.  I love the gearing but as most of you know I am stripping it and hoping the Jeep Truck comes out soon....  :)
I am looking for someone with a 2012 - 2016 Rubicon that currently has 4.10 gears.
What this would be is a direct swap of both front and rear axles (housings and all).
My factory housing has the following:
- G2 Dana 44 JK Front Reverse 4.56 Ratio Gears
- G2 Dana 44 JK Rear 4.56 Ratio Gears
- G2 Dana 44 JK Rubicon Front Master Install Kit
- G2 Dana 44 JK Rubicon Rear Master Install Kit
- Alloy JK Dana 44 Red Outer Axle Tube Seals
- Front and Rear Lower Control Arm Skids
http://www.4wheelparts.com/Drivetrain-Differential/JK-Dana-30-44-Red-Outer-Axle-Tube-Seals.aspx?t_c=12&t_s=237&t_pt=101188&t_pn=ALY11105
http://www.4wheelparts.com/Drivetrain-Differential/Dana-44-JK-Front-Reverse-4-56-Ratio.aspx?t_c=12&t_s=237&t_pt=5092&t_pn=G%2f22-2051-456R
http://www.4wheelparts.com/Drivetrain-Differential/Dana-44-JK-Rear-4-56-Ratio.aspx?t_c=12&t_s=237&t_pt=5092&t_pn=G%2f22-2052-456
http://www.4wheelparts.com/Drivetrain-Differential/Dana-44-JK-Rubicon-Front-Master-Installation-Kit.aspx?t_c=12&t_s=237&t_pt=5094&t_pn=G%2f235-2051
http://www.4wheelparts.com/Drivetrain-Differential/Dana-44-JK-Rubicon-Rear-Master-Installation-Kit.aspx?t_c=12&t_s=237&t_pt=5094&t_pn=G%2f235-2052
http://www.4wheelparts.com/Armor-Protection/Lower-Control-Arm-Skid-Plate.aspx?t_c=79&t_s=467&t_pt=3545&t_pn=SYN8012-03
These above listed parts are $1,444.73 including tax.
(http://uploads.tapatalk-cdn.com/20160519/7f198cf96573716fa897572591349f28.jpg)
This will work for an automatic, manual, 2 door or 4 door.
My housing has also had the front wheel bearings replace within the last year, as well I will be installing new front upper and lower ball joints within the next week.  I change the diff fluid regularly and only use Amsoil Synthetic.
I am looking for $1,600 for this deal.  With labour and shop supplies you would be over $2,500 for this at the shop.
I also bought the 4 Wheel parts warranty which should be transferable but that would have to be confirmed.
Please do not attempt to low ball me or make negative comments. :)
Please call or text as that is the fastest way to get me.
4O3-681-2O4O
Thanks,
Dwayne
Title: Re: Anyone with a Rubicon looking to go to 4.56 gears?
Post by: Ddub1973 on May 20, 2016, 02:02:33 PM
BUMP......OBO...
Post by: FiEND on May 20, 2016, 09:14:38 PM
you don't need to bump after two days.  maybe after it leaves the first page or after a month...
Post by: Ddub1973 on May 20, 2016, 09:16:38 PM
Thanks for the tip, but if you notice it was more so that I could add OBO. :)
Post by: Ddub1973 on May 28, 2016, 12:00:27 PM
Ok so I found out the axle housings are the same from 2007 - 2016.
So anyone with those years that are interested I am going to drop to $1,300. That is basically half price.
