Trading Post => Jeep Stuff Wanted => Topic started by: kailnlsn88 on July 06, 2016, 12:50:23 AM
I'm desperate and need them before Friday. Only require fixed lowers for 4.5" lift. Death wobble has the got the better of me and could really use some help.
...death wobble is caused by trackbar though :o
trackbar wobble.... control arm wobble.... fillings in teeth wobble loose..... It's a progression Jay.
9/10 times yes. But my track bar is brand new, upper frame mount brand new, and axle mount has a washer welded to it, over sized bolt and hole redrilled. That's all tight.
I had a similar issue in one of my ZJ's. Had it aligned, brand new tires, RE adjustable trackbar, shocks, swaybar bushings etc. still had death wobble. Put in some new fixed LCA's with poly bushings....problem solved.
Sometimes it's not always the obvious.
