4x4 Related Groups => Tech Talk => Topic started by: 4Play on July 31, 2006, 10:34:12 PM
Title: Removing rear trac bar
Post by: 4Play on July 31, 2006, 10:34:12 PM
Is it fine to remove the rear trac bar (sway bar) whatever it is called???  I want more flex  :lol:   I already have the front sway bar disconnected.
Post by: calltrex on August 01, 2006, 07:25:52 AM
take front and rear trackbars and front swaybar off if u want. i did.  But i will be trailering mine to where ever.
if u drive it on the street everyday im not sure if u should.
Post by: BlackYJ on August 01, 2006, 07:28:31 AM
In a YJ yes, and you can also remove the front track bar while you are at it.
In the summer I usually drive without my swaybar and my rear track is gone.  Not too bad to drive, but no sports car
Post by: redbull on August 01, 2006, 11:40:03 AM
Another YJ here. 1.5 years with no rear trac bar. Can't tell if anything is different. I removed mine after doing a 2.5" lift.
Post by: evasion1 on August 01, 2006, 01:08:58 PM
I was also considering taking the rear bar off.  Is it safe for me to remove it having a spring over done on mine????  Both front bars are off already!
Post by: BlackYJ on August 01, 2006, 01:27:59 PM
Quote from: "evasion1"
Unless you have another means to control axle wrap, you might start spitting out u-joints
Post by: calltrex on August 01, 2006, 07:28:25 PM
Quote from: "BlackYJ"
Thats what the parts store is for!  :lol:
Title: track bar
Post by: bae146 on August 01, 2006, 08:06:58 PM
Well 2 years with now front and rear track bar and no sway bay and no problems yet.
Post by: Becker on August 01, 2006, 10:10:24 PM
My yj has a spring over and I removed the track bar.
Post by: 4Play on August 01, 2006, 11:50:50 PM
Well it looks like it will be off by the weekend  :lol:   I never thought about taking the front trac bar off.  Maybe I will try it  and see.  The only way to find out
Post by: evasion1 on August 02, 2006, 10:45:19 PM
hop you dont get stuck this weekend man :D  does any one know if 35 well snap a stock ax on a yj
Post by: yjcanibul on August 03, 2006, 12:56:10 PM
for safety I would be conservative if driving it to the trail, I run no rear trac and swaybar disco's on the front,  hard to say what would happen disco'ed on the hwy in an emergency stop as weight transfers here and there ... dont think I would like it ...
I heard a rumor the front trac bar limits articulation by 20% or something on a yj - I am thinking thats about an additional inch,  removing everything wouldnt the bump stops have the final say on gains ?
disco'ed w/bump stops in place my tires just rub into the front flares about 1 inch, any more and they would be perm distored ...  not good for me ...
Post by: yjcanibul on August 03, 2006, 08:19:01 PM
not much flex by some stds but here is a pic of my yj with front sway disco'ed and rear trac off,  you can see my rear tire is "down" sticking out past front passenger tire,  I know front limits by bump stops cause they get shiney black on top ...
not sure on SOA whats limiting your flex ??
in my case pulling off the front trac bar wouldnt gain me anything cause of the bump stops which are saving my stock flares unless I'm confused ....  :roll:
(http://www.msc-inc.ca/maclean_20050801/yj_disco.JPG)
