4x4 Related Groups => Tech Talk => Topic started by: SuicidalPenguin on August 27, 2006, 02:56:36 PM
I'm in the middle of putting in a Lock Right locker, but i can't get the shaft that holds the spider gears out. I popped the cover to find no bolt, but the shaft will not budge, tried just pushing on it, tried a punch and hammer. Is there something i left out to getting the shaft out? I can stick stuff into the bolt hole and it goes all the way through, so i don't think the PO broke the bolt and it's still in there.
Oh yeah, it's the D35 c-clip diff
I just put an aussie locker in my 35 and there was a small bolt holding the pinion shaft in. I removed it and the shaft came right out
I believe it is 10 mm 12 point right?
You may have to use a punch and drive a roll pin out of the case to remove the shaft if you do not have a bolt.
Good luck.
:D :D
