		4x4 Related Groups => General Talk => Topic started by: JasonL_031 on September 23, 2006, 11:42:21 AM
				what type of exhaust are you guys running i have a flowmaster muffler and was thinking about maybe dumping out the exhaust after the muffler or have it go all the way to the back where the factory goes. or even have it exit the side. i was also thinking about yanking out the cat any help would be appriciated thanks jason
				some cat talk in previous topic :
 http://www.calgaryjeep.com/forums/viewtopic.php?t=2856
				do you ever drive with the doors off?   ever been high centered?   ive ripped about 4 steps off the sides.  id hate to rip off some exhaust bits.
				i was planning on using a cherry bomb muffler for a resinator i just don't know where to have the tips cause i am planning on doing this my self and i don't have a pipe bender so i cant really build any compound bends unless someone want to help me this would be the first exhaust system i have built so i need help lol
				If your going to take your cat off you should get the end as far away from you as possible to help avoiding the bad smell and all around unhealthy affects of having no cat.
 I have no CAT and there is absolutely no smell. I think if the engine is in a good state of tune, (running close to stioch.) you shouldn't get a smell. My Pathfinder reeked of sulfur, and that was will all emmisions stuff in place.
				I agree wiht RedYJ, you are gonna want to get those harmfull gasses out the back end...I would do what all the guys talked about in the previous exhaust post and go to a muffler shop and just get them to route you pipe to the end.
 I ended up picking up a Borla Cat back system and love the sound!!
				Use a bent peice from somewhere else in the tail pipe, spit it out sideways a few inches back of the muffler.
 If the cat has an 02 sensor, leave it be. If not, you can cut it out.
 Make sure you have that bend. Your muffler will fill and plug with mud if you dont.
