4x4 Related Groups => Tech Talk => Topic started by: JasonL_031 on November 04, 2006, 11:06:22 PM
Title: TJ STARTERS
Post by: JasonL_031 on November 04, 2006, 11:06:22 PM
ok what year starters use the same one for a 03? cause i went to crappy tire to see if they had one and they said that the vehicle is too new for them to carry the part or some bs like that so i am wondering what years use the same starter for a 03 with a 4L 5 spd manual?
Thanks Jason
Title: TJ STARTERS
Post by: BlackYJ on November 04, 2006, 11:44:28 PM
I put a newer TJ starter on a 94 XJ 4.0 with no problem, just a different ground connector.  The starters from what I know are all the same
Title: TJ STARTERS
Post by: ramtuff on November 06, 2006, 11:26:49 AM
the main starter body is the same but the connection at the solenoid can be different.  If you want a direct fit starter you need 03-06. if your solenoid is still good swap it on to an older starter and save yourself a few bucks.
Title: TJ STARTERS
Post by: captaincrunch on November 07, 2006, 10:08:36 PM
Give Rich at ATI a call 250-2845.  :lol:
Title: TJ STARTERS
Post by: boggjr on November 07, 2006, 10:28:14 PM
ya i would give rich a call  :wink:
Title: TJ STARTERS
Post by: JasonL_031 on November 23, 2006, 12:31:45 PM
could i swap a starter solinoid from a 98 into my 03 starter? cause that is what the problem is i think let me know thanks jason
