4x4 Related Groups => Tech Talk => Topic started by: 4Play on January 03, 2007, 03:31:01 PM
Just looking into for a friend. He was told by a mechanic that his rear pinion gears were gone and needed to be rebuilt for about 7 bills. I was thiking he could just find a rear end on here and swap the rear end out in a garage. Any ideas if that is the way to go and if anyone has one for sale. 91 XJ. How much it would cost if someone here would be willing to do the work????
450 installed have two rear diffs sitting here.need to know if its a dana diff or a 8-1/4 chrysler diff
Whats the easiest way to find out??? Serial number and call dodge?
look at the rear diff and mounted to the bolts that hold the diff cover on will be a tag.I need the numbers off it.Shoud be able to find one of these numbers on it 3.08,3.54,3.73,4.10.If the rear tag is missing check the front diff cover for a tag.then look at the rear diff cover does it look more round or more like a stop sign with sharper corners need to know which it looks like.If thats your jeep in the pic look at your rear diff you will have the dana diff(round looking)
This should help.
http://www.californiajeeper.com/axle.htm
Also, here's a DANA 35, has a rubber fill plug. Look like yours?
(http://i3.photobucket.com/albums/y74/Hondaddict/ChiefDiff.jpg)
The 8.25 axle is flatter on the bottom
Did you call me Fat?
I don't know what you are talking about Dom, it says flatter, so nobody was calling you fatter, 8) 8)
Got to love administrator priviledges
Dom, he's not calling you fat. He's saying your bottom is flat.
How he even notices this stuff is a mystery.
Holy thread hijack....! :lol: This is the way he is gonna go. Does it matter if I screwed up and its a '90.
Prolly not, so long as you get the ratio right.
If it is a 90, than it is most likely a Dana 35 axle
yup in a 90 it should be the dana 35
Actaully what it SHOULD have been was a D44 but Chrysler cheaped out and put in a D35 instead. :D
