4x4 Related Groups => Tech Talk => Topic started by: murdajeep on January 18, 2007, 05:36:27 PM
Is anyone out there running the 3.5 Superlift lift kit?
How is the ride and does it have good articulation?
What is the clearence like?
any pics?
any pics?
My 88 had one on it for a while , great ride , not all that impressive flex , if you use the brackets that clamp to the axle tubes which limit up travel, it would be better to use extended bump stops.
I broke two of the springs , it was dealt with by putting through a warranty claim. Instead of using another set of those springs , I removed the entire kit and bought Rubicon express 4.5" springs . Those went on at the same time as the Dana 44 axle swap , .............. I shoulda spent a little more time researching shocks . I really like the Rubicon springs , the shocks ( Superlift ) need more extension / travel to get max flex out of them........ to be fixed later.
ya i know it isn't going to be a hard core lift like
the RE but I want something decent that will ride nice
and will stand a bit of aggression when I go to find my fishing
'spots.
Is this kit worth it?
And do you recommend those shocks with the kit
or any other suggestions.
Thx
A lot of people seem to like the BDS kits and it comes in a 3.5" lift. Second choice would probably be the standard RE kits
BDS that is Black diamond?
Really the RE standard havn't heard much about them.
No BDS is something like Big Dicks Suspension. A lot of people say the ride is decent, flexes well, is reasonably priced and it carries a great warranty, lifetime.
Ive got the lift on my YJ. It rides fairly well and has decent flex from what I know, I have only owned one lift so I don't really know. I bent a spring getting pulled out of a icy hole, and it wasn't covered under warranty. Its not that bad for the price.
