4x4 Related Groups => Tech Talk => Topic started by: djp on March 13, 2007, 09:36:28 PM
Im looking at buying a 98 GC With a 5.9l, what are your thoughts on the motor and drive train for a truck build?
You will have a better end product than an xj because the frames in the zj's were built stronger but the project will cost more because the lifts are more $$$ and the 249 t-case is junk.
great project build. i like it.... strong engine, and the tranny is ok too. no worries bout future engine swaps, main reason i'm doin git with my 95'. as for the 249, I think junk is a little extreme. if you are using this as a DD like me at the moment it is great. 4low you can still lock it up. however, it does have issues; the Viscous Coupler has a tendency to blow up in thes TCs, however, the swap over to a NP 242 is not complicated; in some cases straight bolt in. as for aftermarket, yes it is a little more expensive, this is true; however, my grand flexes pretty good, we'll see just how good this summer at teh show & shine, but i would pit it against a TJ anyday....
IMO if you want to build a unique jeep, this is a good way to go; V8 power in a coil sprung vehicle. its nice. drop 2gs on suspension, run some 33s and you'll be surprised how it holds up
Took my basically stock 93 ZJ out on it's first run last summer with the CJA on the Aug. 19th stocker run, and was very impressed with how it handled things. With mods, one of these rigs would be very capable.
Check out www.nagca.com or http://www.mallcrawlin.com/
i run a 98 zj with 5" lift and 31's..... it flexs great and climbs great and the disks all around are a plus. not to mention that you can actually carry a whole lot of camping gear / people unlike a tj or yj. i had an xj before and the zj flex just as good if not better then it. both were able to lift a tire 2 feet off the ground with no problem. the lifts do get a little more expensive the higher you go but they are worth it.
My next buildup will probably be a ZJ. The 5.9HO are awesome and very rare. Very powerful. My mom has one. Would almost be a shame to beat one of those offroad. Lots of fun on the street.
I was looking at a ZJ as they are a little bigger than an xj. What other engines are offered in the ZJ other than the 5.9? That's probably the only engine I WOULDN'T want due to the mass fuel consumption (not sure why they are so much worse than other slightly smaller engines).
4.0L
4.7L
5.2L
5.9L
Depending on wheather you look at the ZJ or WJ
i have a 98 zj and a 01 wj both with the 4.0L and am very happy with the performance that it gives these jeeps
My family has 5 ZJs and 2 XJs in total.
In the ZJs we have two identical '93s with the 5.2L(318), one '94 with a 4.0, one '96 with a 4.0 and one '98 with the 5.9(360).
The 5.9 was only offered in '98 as a special option, its not a regular 5.9(like what you'd find in a truck) but a HO version. Compression has been increased and it uses more agressive engine and tranny programming. Also the tranny is stronger than found behind the 5.2L. Power and torque is unbelivable! BUT because its high compression it requires premium fuel. Its VERY expensive to drive. Usually comes fully loaded and as such the price will be much higher than a comparable 5.2 or 4.0 ZJ. Thus why I'd not buy one for a trail rig, money saved on the intial purchase could be used for lift, tires, etc.
The 5.2 is a great engine and pushes the ZJ along nicely. Much more economical than the 5.9 but not anything I'd consider "effecient". Also its REALLY tight in the engine and difficult to work on.
IMO the 4.0L is anemic in the ZJ for a street driver, maybe thats because I'm used to the V8 and doesn't seem to get much better milage than the 5.2L, maybe 2mpg. However it would be much choice of engine for a trail rig due to its reliabilty, low end torque and ease to work on. Also some '93 4.0s got the AW4 tranny which is almost bulletproof.
Thank you for all your info guys.Out of the 4.0 and 5.2 what is the stronger motor or most reliable? Thanks
The 5.2 definatly has more HP in it than the 4.0L. Both are VERY reliable motors the 4.0 is the old 258 motor and has an excellent track record. The 5.2 is Dodge's old 318 and is an great motor as well, my dad had an '86 Ramcharger that he put over 400,000kms on the original engine.
If I had to pick one for reliabiltiy I go with the 4.0L, its also WAY easier to work on. The 5.2 is really crammed in the ZJ and difficult to work on.
If I were to build a ZJ for a DD and mild trail rig I be inclined to go with the 5.2L, then the power lost to the bigger tires won't be so noticable. However if you communte more than 50km to work everyday you may want to consider buy a Honda as well as you won't like the gas milage you'll get from a lifted V8 ZJ. :shock:
I personally prefer the 4.0L,its been really reliable,strong,and impressive with 35's in the rocks.The 5.2 is also a good choice.I believe4.0 is more commin ,and I believe has more after market parts,cheaper then the 5.2.Etheir way,the right gear ratio can make that zj move like its got a hemi!
go with the 5.2 IMO. do some lil' power add ons and your pushing over 250hp at least. its nice. i have 33s on mine, with the tow package. goes cool on the street, but crap gas milage (and now for somereason stuff makes noices lol i think its all susp. though) i can't wait to run some new agressive tires with 5.5" of lift this summer, its gonna be capable
What would you prefer xj or zj?auto or manual? I would like to run a 3.5 lift, but also use it as my daily driver. This will be my first jeep just want to get it right!
i have had both.... granted they were of different vintages, xj was an 88 and the zj is a 98. the xj is easier to modify and has a greater aftermarket support. the zj is harder to modify with lesser support from the aftermarket and a lot more expensive in terms of lift kits :( . when it came down to it.... the zj is a much more capable trail machine with the link suspension in the rear compared to the leaf springs in the xj 8) . if you go the zj route try to get one with a 242 tcase. some of the earlier awd cases never locked the center diff even in low :shock: ( from what i have been told) as fo the manual or auto... matter of preference.... i like the auto :wink: ...granted i am probably going to convert it to a manual valvebody :twisted: . i find with the auto you don't have to do the 3 pedal shuffle :lol:
just my .02
On the zj's(6 cyl.), can you just throw your front springs on the back, and get the V8 springs for the front and end up with 3" of lift ?
if you do want to do the coil swap it is possible, however you would need new front coils, from an upcountry offroad package. so ya, swap your current front coils to the rear, and put the new, stiffer upcountry springs up front; however, even then it will only give you any lift if it is a 6cyl, so yes, its possible, however, for the net lift you will get, might as well just do a coil spacer lift IMO. i think you can get bout 2" or so. i guess you can also add the spacers for 4", but then your running into all the other problems like, control arms, sway bar discos, shocks, etc..... either way you need new coils for the front, and will have to buy em somewhere, unless you can find some used ones. but like i said, the upcountry ones are the only ones that'll give you any lift.
personally, i like the full kits, i would even say its idiot proof lol, i mean I installed it myself, so it can't be crazy hard, and it rides decent too. if you want to keep it very street capable, spring for the full lift kit, and get some good, adjustable shocks. it'll ride better than stock.
OK guys I think I found a cherokee <but it is an 97 XJ 4.0 Just wondereing if Im wasting my time with an XJ or should I just buy a ZJ with 5.2 and be done with it? I know thers a huge following on the web with XJ owners and they seem to love them, but after Im done with a lift and so on is it just going to be a gas guzzling no power truck as a daily driver? Thank you for all your comments and suggestion!!!!!!
I know, just get your crap together and buy one!!!!!!!
For the front to rear spring swap the Upcountry V8 front springs will give you about 4" of lift when moved to the rear, standard V8 springs will only give you about 3".
There is a good write up here
http://www.jeepforum.com/forum/showthread.php?t=150055
just scroll down partway down the page for the front to rear swap info.
I also have my eyes on WJ with 4.0L.Now in the WJ would the 4.0L be way under powered with a lift and tires? Thanks
