4x4 Related Groups => Tech Talk => Topic started by: fony3 on June 10, 2007, 07:59:27 PM
Title: Master Clutch Cyl. Leak
Post by: fony3 on June 10, 2007, 07:59:27 PM
Ok, So my clutch went soft on me Friday and i tracked it down to a leak coming from my master clutch cylinder. I am guessing the next step is to take it to a mechanic or is this something i can diagnose and fix?
Looks like this is a weak spot on jeeps?
Cheers,
Brad
Post by: Bnine on June 10, 2007, 09:53:34 PM
They go once in a while, but usually they are fairly reliable.
Buy a new one and change it out. Follow install directions for bleeding the air out.
Really simple fix for the most part.
Post by: fony3 on June 11, 2007, 12:28:53 AM
Ok, i'll give that a shot. Should i consider changing the slave too, or is that just gonna be a waste of time and money?
What time of fluid do i need? DOT 3 or 4?
Post by: BlackYJ on June 11, 2007, 07:20:52 AM
Just a word of caution, and I don't know if it is for all external slave system for YJs and TJs, but when my slave went, I have to replace the whole system.  I purchased it from chrysler and it already came charged with fluid.  The price was pretty reasonable too.
Post by: fony3 on June 11, 2007, 10:48:43 AM
Ok...found the dealership one...355 bones for slave, master, and pre-bled.
Found one Master at NAPA for a 97-01, i am assuming this would work for a 2002? Its only 113.59, but i couldnt find any clutch slave cylinders.
Is it worth tripling my price for both?
If i just do the master, i can "bench bleed" that, but i am guessing i need to bleed the entire system after.
Thanks.
Post by: BlackYJ on June 11, 2007, 11:13:12 AM
Quote from: "fony3"
OUCH - mine for only like $200 for the entire system from Chrysler
See the problem with mine was the slave did not have a proper bleed screw, so therefore could not really be bleed.  Mine could be different from yours.  Take a look at your slave and if there is just a hex head screw on top, my guess is you will need the whole system.
But like I said yours could be different, so do your homework.
Post by: fony3 on June 11, 2007, 11:36:19 AM
Ok, snapped a couple pictures. BlackYJ, i think you are right, i see no bleeder valve, is this something that can be purchased that may screw into there?
(http://i69.photobucket.com/albums/i54/fony3/Jeep%20Stuff/IMG_1504.jpg)
(http://i69.photobucket.com/albums/i54/fony3/Jeep%20Stuff/IMG_1506.jpg)
