4x4 Related Groups => Tech Talk => Topic started by: XJHERO on January 14, 2008, 08:52:41 PM
ok so does a 4.2 L 1987 yj moter bolt up to a AX15???????
and work?
and work?
Yup , you should look at the pilot bearing size , it's likely different.
There's the 21/23 spline TC input issue , some bolt holes in the skid plate that don't line up. Other than that , the install should go well.
thanx man ;D
Ok the clutch peddel has no resistance on it. the resivor is full and when i take the bleader screw out and let it gravity bleed nothing comes out not even when the bleeder screw is taken out.
any one know why that would be.???
Interneal slave 87 yj
Dom is an expert at bleeding clutches, call him and ask him for some help, i'm sure he will gladly drop by for you, he loves the clutch
