4x4 Related Groups => General Talk => Topic started by: myke on May 02, 2008, 06:24:48 PM
Title: Rear leaf replacement in 1992 XJ
Post by: myke on May 02, 2008, 06:24:48 PM
I'm just wondering if it's as difficult as i've heard to replace the leafs in the back of a Cherokee?  If it's going to be that hard, i'm just going to get my mechanic to do it.  Any info on this dilemma would be appreciated.
Title: Re: Rear leaf replacement in 1992 XJ
Post by: WagoneerXJ on May 02, 2008, 07:37:10 PM
It's pretty strsight forward to do. Just don't remove the top leaf spring...The bolt at the front of each top spring is a pain in the arse. There's a welded nut on the inside of the frame and most times you'll either snap the bolt, or break the welds on that nut. Then you have to start cuttin the floor to get access to it.
 My suggestion is to take the leaf spring packs apart and replace the other springs. I've done it many times.
Post by: dubbleJs on May 03, 2008, 02:43:32 AM
I agree the front leaf bolt at the frame can be NO fun...blast all the bolts and bushings with PB blaster for a few days before and use some heat if it gives you any grief. Otherwise get ready to start cuttin!   :o
Post by: rws on May 06, 2008, 08:31:48 AM
Where can you buy PB Blaster in Calgary?
Ron
Post by: dubbleJs on June 02, 2008, 04:56:52 PM
Sorry for the late reply. Can Tire sells it..
Post by: Waytec on June 03, 2008, 05:07:50 PM
If you don't feel comfortable changing them yourself their are several guys on this sight that do side work from home that have the plasma cutters and welders for the worst case scenario. I had to cut the springs out.
Post by: BrokenAxle on June 04, 2008, 07:40:48 PM
yeah, his jeep is no longer welcome at my garage...  what a PITA!
