4x4 Related Groups => Tech Talk => Topic started by: JasonL_031 on May 08, 2008, 10:09:26 PM
Ok i installed a 2 inch body lift a few months back and ever since i installed it i am having issues getting my jeep into 4 hi or N or even 4LO i need help cause this is starting to really squirt me off. my jeep is a 03 Tj Sport please get back to me soon.
Done a few body lifts on Tj's, and just wondering if you trimmed a little of the floor surrounding your tcase shift?
Did you use the supplied relocation bracket, and reset the linkage when it was all said and done?
skyjacker makes a nice linkage addon...
I have a 2 inch body lift on my 01 TJ and in my experience the only adjustment nessesary was to get under there and jimmy your linkage around until it shifts better. The only time you should need to get into the skyjacker bracket is if you are 3 inches of body with a t-case drop kit in. When you have a t case drop with the body lift it really pulls stuff out to lunch. I bought the skyjacker bracket and it just didn't work for me. I ended up just lengthening the stock linkage to its extent. No problems shifting anymore.
