4x4 Related Groups => Tech Talk => Topic started by: JackstandJohnny on May 24, 2008, 12:15:26 PM
Title: ZJ starting issues
Post by: JackstandJohnny on May 24, 2008, 12:15:26 PM
so this has been a recurring issue that i think has finally settled into a problem.  sometimes when i fire up the ZJ (5.2LV8)  it'll rev to 800, then die right down and stall.  when i try to restart it, it'll kick over but won't fire until i give it more gas, then someitmes it'll catch..  most times, i'll just feather the gas pedal and play with it, until it starts to idle again, however, this morning, it didn't want to stay idling at all. it just died.   so i'm wondering what this is.  pulled the codes, got 12, 32, 55,  32 is an open or shorted condition detected in the EGR solenoid circuit, possible air/fuel ratio imbalance not detected during diagnosis.
so my rudimentary analysis tells me i should replace the EGR correct??????  on a side note i just went and fired it over 5 minutes ago and it fired up, but ran really rough.... off to Auto Value for me???
Title: Re: ZJ starting issues
Post by: AMCJeep on May 24, 2008, 10:06:22 PM
John,
Try your theory and pull the EGR and clean it up, but my bet is on the battery or battery posts/wires/contacts. I've experienced this several times in the past and it has always been those darned battery leads or terminals!!! >:( I finally gave in and put new terminals on and re-dressed the wires and no problems for 3 years now.
Post by: cLAY on May 24, 2008, 11:49:24 PM
My '93 V8 had a similar problem as well as my dad's '90 XJ 4.0. Both times it also had an intermittent hi idling problem. Turned out it was the idle selonid valve. Replaced with new and problem was gone.
Post by: cLAY on May 25, 2008, 11:12:29 AM
Now that I've slept I remember what Chrysler calls that valve.
IAC-=idle air control valve
Post by: JackstandJohnny on May 27, 2008, 10:21:24 PM
thanks pete and clay... i will pull the EGR and clean it, kind of a pain to pull but if its just a stupid valve or what not its worth a good cleaning.  now that i think back too, i remember having another problem with the IAC in Penticton a few years back... i remember i kept stalling out on steep declines. i had just cleaned it up and it worked well, but i think it may have to be replaced..........  i took it for a spin today too and it was running fine, so, hm, i don't know. sometimes it runs and sometimes it doesn't lol. gonna investigate now
thanks again
John
