4x4 Related Groups => Tech Talk => Topic started by: peter060 on June 12, 2008, 08:36:15 PM
I have a 87 Cherokee, Just got it on the road, I'm having a problem of the front almost locks up when in 4WD and going in reverse. I know the front drivers U-joint needs replacing but it's not that bad as to cause a lockup.... Any hints ????
what exactly is locking up?
Well it seems that the front diff partially jams , it seems to happen morewhen turning the wheels to the right, almost like the brakes are engaging , it drags
pull the diff cover and check?
how bad is that u-joint? it could bind things up.
Just curious.... where do you test it also.. on the pavement? You Heep on 4WD will never turn properly on the pavement...I'm sure you know that... just checking ;)
Change your u-joints (do NOT buy the cheap u-joints... get Spicers.... trust me) and check your wheel bearings...
