4x4 Related Groups => Tech Talk => Topic started by: Duncan71 on July 22, 2008, 12:43:16 AM
Title: Clutch does not disengage... slave cylinder?
Post by: Duncan71 on July 22, 2008, 12:43:16 AM
Hey guys,
I just finished installing a 4" lift in my 1992 YJ, and took her out for her first drive today but I quickly noticed that the clutch is not fully disengaging making it impossible to shift into first. I could adjust engine speed and get it into all the other gears and limp her home. When I have the pedal fully depressed with nothing on the brakes the vehicle creeps forward much like an automatic trans does.  I also checked for leaks and although the fluid isnt that low, I did notice there is some fluid leaking from the bellhousing.  The odd part though is that the vehicle gets worse the farther I drive it but when I first start driving it, it almost seems ok.   Does this sound like the slave cylinder? The motor is a 4.OL H/O and I was required to install the 1" transfer case drop kit. You guys got any suggestions?
Regards,
Duncan
Title: Re: Clutch does not disengage... slave cylinder?
Post by: familyofjeeps on July 29, 2008, 12:42:29 PM
hey I am kind of having the same problem with my Jeep but my problem is the tranny is falling of but when my slave went the same thing happened if you bleed the clutch and it work for a day or so I think it would be safe to say it is your slave if it keeps working you might have gotten to low on the dot 3 for the clutch
hope I was some help
family ofjeeps
Post by: JohnB on July 29, 2008, 12:53:08 PM
You probably have some air in the system.  Bleed it baby, bleed it.
Post by: Duncan71 on July 29, 2008, 01:05:59 PM
well I yanked the tranny and the slave was leaking, and then I looked at the master and it was leaking, and then I figured what the hell lets replace the clutch too, so 500 dollars later, well see if this thing work properly!
