Author Topic: jeep yj clunking from rear when turning left  (Read 1028 times)
Jeepster
« on: December 05, 2008, 01:34:28 PM »
Just started happening this morning
Getting a clunk sound from what seems to be the passenger rear.
Rear tire seems to almost stop rotating as well, I noticed it squeal on  the pavement.
Turning right there is no isuues , its just turning left.
Any thoughts ?
Re: jeep yj clunking from rear when turning left
« Reply #1 on: December 05, 2008, 01:43:15 PM »
Spider gears and or limited slip clutches, and or both are trashed.
Pull the cover.
Offline fug
  • Airdrie Pick n Pull
« Reply #2 on: December 05, 2008, 01:50:40 PM »
Is the rearend a dana 35? drum brakes? any kind of locker?
Your best bet is to get it up on jack stands and start pulling stuff off.
Fug
TJ Rubicon
« Reply #3 on: December 05, 2008, 06:17:28 PM »
i just saw a tj with a left rear brake that pretty much came appart. it locked up and you could barely move it. could be the beginning to your clunk. pull rear wheels, pull drums or rotors. check brakes, if all is well, then pull diff cover and watch your xmas money fly away:) sorry to say...
« Reply #4 on: December 06, 2008, 10:34:04 AM »
Good time for an axle swap......................
