Author Topic: Cooling issue WTF  (Read 1316 times)
Offline Mudhawg
  • Rig Life
Cooling issue WTF
« on: April 26, 2009, 01:35:15 PM »
did the waterpump in my cherokee yesterday with a new thermostat went to run it today heater full blast everything like that and it still overheats and i dont get any heat in the interior... WTF?
Offline WagoneerXJ
  • Bagon Wagon!
Re: Cooling issue WTF
« Reply #1 on: April 26, 2009, 01:50:23 PM »
Did you bleed the air outta the system?
84 Mustang GT-Built 351W 5spd
Offline Mudhawg
  • Rig Life
« Reply #2 on: April 26, 2009, 02:20:01 PM »
burped the system its all good now
Offline WagoneerXJ
  • Bagon Wagon!
« Reply #3 on: April 26, 2009, 03:35:42 PM »
 8)
« Reply #4 on: April 26, 2009, 08:27:32 PM »
The 4.0L can be a real pain to burp air out off. I ended up buying one of those flush kits just for the "T" fitting. When I filled up the system I would take the cap off of it to let the air bleed out while filling. Helped a lot.
No heat from the heater is a good indication that the system still has air in it.
Offline S-FLY
  • '94 XJ
« Reply #5 on: April 27, 2009, 11:11:59 AM »
How long did it take you to swap the water pump?
ve1sly
Offline slimbeam
« Reply #6 on: April 27, 2009, 11:58:20 AM »
are you sure the new thermostat was working properly, are you sure you didn't put it in upside down, was the system flushed
Offline S-FLY
  • '94 XJ
« Reply #7 on: April 27, 2009, 12:29:53 PM »
He fixed it, air in the system.
ve1sly
FullMetalJeep
« Reply #8 on: April 27, 2009, 01:09:14 PM »
snap on makes a good vacuum rad filler. I love it so much, it always bang on and it suck out all the air and left over coolant before replacing it with fresh stuff.. it really is a must have for guys that do cooling systems every now and then. its clean, its reliable and it takes the guess work out.
think its about $150 (!!!) and its cheaper and way superior to the real sh*tty Napa one.
Offline Mudhawg
  • Rig Life
« Reply #9 on: April 27, 2009, 01:10:00 PM »
took me 45 mins start to finish to do the waterpump  ;D no fawking around
Offline S-FLY
  • '94 XJ
« Reply #10 on: April 27, 2009, 02:12:20 PM »
Told ya it was easy... and you wanted to sell the jeep!  ;)
ve1sly
Offline Mudhawg
  • Rig Life
« Reply #11 on: April 27, 2009, 04:18:17 PM »
bigest pain was adjustin the belt tention hahaha
« Reply #12 on: April 27, 2009, 08:40:34 PM »
Ya thats a really dumb setup for the belt tension. I find it easiset to just pull out the airbox.
BTW the t-stat usually has a small valve in it on the outer ring. Make sure its at the 12 o'clock position when installed. Its an air bleed.
Offline Mudhawg
  • Rig Life
« Reply #13 on: April 27, 2009, 08:42:13 PM »
ya i ditched my air box in favor of a K&N for the street so it made it easier haha
