Author Topic: SWR Meter  (Read 2643 times)
Offline Fredduck
  • RIDE ON
Re: SWR Meter
« Reply #15 on: June 30, 2009, 08:29:46 PM »
If SWR is higher on 40 than 1, then antenna is too long, if SWR is higher on 1 than 40, then antenna is too short.  Or tune for lowest SWR on the most used frequency(Channel), 10 for club, 9 for emergency, 19 for typical trucker calling blah blah blah :)
In my experience, adding a spring to the mount effectively lengthens the antenna.
I want to carry out some experiments, as I've been taught as a CB person years ago that cable length mattered, as a HAM, I'm taught by the vast majority that it doesn't matter, but then came across a very technical, lucid article that explained that in an IDEAL setup with perfectly matched antenna, coax and transmitter it doesn't matter, but since this is real-world and they seldom perfectly match, it can make a difference (technical details left out).
I plan to do some experiments  ,  with cable lengths to see what I come up with "real-world".
I used a 12 foot cable and a 4 foot 5/8 firestick.
The size of the meter on the unit isn't great.
What difference in SWR between channel 1 and 40  matters?
Re: SWR Meter
« Reply #16 on: June 30, 2009, 08:58:26 PM »
Using the same antenna (tuned the same) your SWR will be a little bit different on each channel. This is due to the fact that each channel is a different frequency (and thus a different wavelength). As the wavelength changes with respect to the length of the antenna, the SWR will change.
Clear as mud, right?
Offline Fredduck
  • RIDE ON
Re: SWR Meter
« Reply #17 on: July 01, 2009, 06:33:19 PM »
I DID IT...I DID IT...I DID IT
I left home and stayed in a HOLIDAY INN EXPRESS last night,
then I re-read the instructions and tuned my own antenna.
DUB-squared, thats for the offer and all the support.
