Author Topic: overheating  (Read 2468 times)
Offline giorno71
Re: overheating
« Reply #15 on: August 04, 2009, 06:32:01 PM »
the rad is totaly clear of mud and debre and i do have a winch but have never had the problem wth the winch before.
Re: overheating
« Reply #16 on: August 04, 2009, 09:16:29 PM »
I had the same problem when I swapped my 4.0L in.  It ran great for 2 summers and then started getting pretty warm.  This spring I just swapped in a heavy duty rad and it runs great
Offline Evil-Jeep
Re: overheating
« Reply #17 on: August 05, 2009, 10:15:59 AM »
A bit of a longshot here...... are you actually overheating or are you just going by the gauge? It could be a bad  sensor or a bad reading between the sensor and the computer. If you are running in the red I would think you should atleast see a little fluid in the overflow.
Offline giorno71
Re: overheating
« Reply #18 on: August 05, 2009, 06:32:02 PM »
yep was going by the gauge then swaped it out...same thing... but yes it is over heating the coolent in the overflow looked like it was boiling... front end gets very hot and the firewall and floor at the shifter radiates a lot of heat
