Author Topic: please help. no idea  (Read 1778 times)
Re: please help. no idea
« Reply #15 on: August 11, 2009, 09:07:51 AM »
The 195 sounds right
« Reply #16 on: August 11, 2009, 03:40:37 PM »
Its either what clay said about the computer finally recognizing no post 02 and cat,  or its a bad temp sensor. Either one will leave your rig in open loop and cause really rich starts, and poor running.
Otherwise, only thing left is a bad injector. If you have an injector that is bleeding, it will act the same way. Pull the rail and see if an injector is leaking.
Offline BUKI
  • Project Fugly
« Reply #17 on: August 11, 2009, 09:36:12 PM »
im starting to get lots more mileage now.  im already at 142kms and still half a tank.  thanx for everyone's  help.  the quest for mileage is sooo expensive.
« Reply #18 on: August 12, 2009, 08:31:03 AM »
Sounds like during the stat change, you may have inadvertantly fixed up the temp sensor. A warmer stat really wont make a significant different, although it will make a really small one due to operating at the proper temp/efficiency.
If your problem comes back, look to that sensor, or possible the pigtail for a cracked wire.
