Author Topic: September 6th  (Read 14573 times)
Offline Tagg
Re: September 6th
« Reply #60 on: September 06, 2009, 06:49:55 AM »
I'll be there for sure....can't wait.  Look for a black JK
08 Rubicon
Offline jeeptastic
Re: September 6th
« Reply #61 on: September 06, 2009, 07:20:51 AM »
See everyone out there. Hope you still come.
Offline turbojohngt
Re: September 6th
« Reply #62 on: September 06, 2009, 08:20:09 AM »
See you all in 41 minutes! ;D
07  Sahara, silver (AKA The Minivan) 4 door jacked with toys.
08 Rubi clone, Detnator yellow 2 door bare bones.
04 Srt-4, The fully built 450 hp 11sec family car.
Offline muffintop
  • You spilled my macchiato!
Re: September 6th
« Reply #63 on: September 06, 2009, 02:15:48 PM »
I had a squealing sound that I thought was mud and/or rocks stuck in the brakes... so instead of going wheelin today... I took it apart, cleaned & inspected... only to find the drivers side unit bearing (front axle) has a "huge" amount of play in it, has lost its lubrication and is pretty much shot.
I'm not sure how dangerous it is to drive around with a unit bearing in that kind of shape... but man am I glad I decided not to go wheelin.
What did I learn?
1) When ya start with a 190,000km Jeep, rebuilt the axles and put bigger tires on it... while your in there... replace the unit bearings with new ones ($400)
2) A "quick and dirty" way of checking unit bearings without jacking your Jeep up is ... start in the back (even though there are no unit bearings back there on a stocker) it will give you a frame of reference. Push & pull hard sideways on the top of the tire and feel for play (none in my case) other side on the back was the same... no play, passenger front I could feel a bit of play in the unit bearing, drivers side front... Whoa... bingo... HUGE play.
3) If you have a sound you think is mud/rocks related... dont assume... check it out.
I would suspect the bit of front end shimmy/wobble I have at 80 & 110km/hr will go away with new unit bearings
Just thought I'd share  :P
« Last Edit: September 06, 2009, 09:23:10 PM by muffintop »
2014 Jeep SRT
Offline jeeptastic
Re: September 6th
« Reply #64 on: September 06, 2009, 08:43:38 PM »
Thanks to the three other Jeeps(Jen, Jim and John) that made it out today. We had a blast. I am so Amazed with what my Jeep was able to accomplish.
I think I am way over the mud and water... The next time we go out I am putting out a bead of silicone or something around my distributor cap. Thank You everyone for being so patient.
The real fun was making it to the Top of the World. I still cant get over that steps in the rock that we went over.
I am really looking forward to the next time we head out.
Thanks Again.
Offline turbojohngt
Re: September 6th
« Reply #65 on: September 06, 2009, 11:43:54 PM »
Thanks Again.
Glad you enjoyed man,great day had by all to say the least.Hope to see you guys at the next outing. :)
