Author Topic: 258 carb upgrade  (Read 1057 times)
Offline Tanner
258 carb upgrade
« on: October 01, 2009, 12:55:24 PM »
I am told the Weber 38 2bbl carb is a significant upgrade for the older 258 6cyl engines. Has anyone installed one of these. They are pricy so I am looking for some feedback before dropping cash on one
Re: 258 carb upgrade
« Reply #1 on: October 01, 2009, 04:13:01 PM »
Hps4evr would know a lot about this carb. Pm him. He likes to help people. Don't you Eric? ;)
« Reply #2 on: October 01, 2009, 06:42:19 PM »
what the hell do i know about carbs??? fuel injection is a much better idea. carbs make no sense to me.
anyways. from what ive seen the weber is the cats meow on the older CJ 4.2L. if its the YJ 4.2L i think the popular and cheap swap is a motorcraft 2bbl carb. or a carter of some sort. please dont quote me on this. its all jiberish to me. but ive read this some where. try the google button.
Offline slimbeam
« Reply #3 on: October 01, 2009, 07:38:34 PM »
if you do a nutter bypass on a factory carter carb that will cure 90% of the carb problems; as for a weber Ive herd good and bad , my cousin has a weber on his 89 YJ and has problems starting it even if it only sits for a day an dhe lives in Alabama where it dont get cold
Offline AMCJeep
« Reply #4 on: October 02, 2009, 01:00:58 PM »
Just for your knowledge, the "Nutter Bypass" is not for your carb, it's to bypass the computer controlled ignition system. The Bypass DOES eliminate the computer so they ask you to warm up your motor first, then unplug the carb so the enrichener needles go to full rich.
I would highly recommend the MC2100 on any AMC 6 cyl carb'ed motor be it a YJ or CJ 4.2L. There is another option of one of my silly FrankenCarb inventions. You need a 2 barrel BBD from any Dodge 318. Remove the Jeep baseplate and top section and swap it over to the 318 center section and you have then eliminated the computer section, lower the float level to 7/16" then set the mixture and you have a great combo that will rival the MC2100 for off-road capability and power.
The Weber is a great but spendy carb for the AMC 6.  Some people have reported trouble tuning them but it's really just experience that will dial it in perfectly.
My 2 bits, do the "Nutter Bypass", then make a FrankenCarb, adjust it and never have to touch it again. Cost = $50 at the most.
03 Ram 2500 QC, LB, 5.9 CTD
« Reply #5 on: October 05, 2009, 05:10:05 PM »
there, we found the carb guru. leave me out of this;)
