Author Topic: Roll cage tubing, any thoughts?  (Read 1695 times)
Offline mike s
  • Good times!
« on: January 06, 2010, 11:40:17 PM »
Looking 1 3/4" tubing for roll cage add-on's. Anyone know who/where and what is best? Want to add front uprights and dash bar, wondering if anyone knows what is the best to get.
oldEnuff2NObetter
but still can't help myself
Offline muffintop
  • You spilled my macchiato!
Re: Roll cage tubing, any thoughts?
« Reply #1 on: January 08, 2010, 05:46:55 AM »
Hey Mike... here is my $0.02 Canadian...
Common "recreational" roll cage tubing size is 1-3/4 x .120 wall ERW or DOM.
You can run a mix of DOM & ERW (i.e. DOM for bent sections & ERW for straight sections). If your not going to use up a pile of tube... I would just buy DOM and be done with it. On small quantities... the price wont be too much different in the end anyway.
Unless your building a race car/truck/Jeep... stay away from 4130 (this ones probably obvious).
Material choices are pretty much broken down as such (I cut and pasted this off a website):
1) Hot-rolled ERW (HREW) tubing varies in dimension too much and is supplied with a rough, scale-covered finish, making it unpleasant to work with and requiring cleaning
2) Cold rolled ERW (CREW) is stronger, cleaner, and has better dimensional tolerance than HREW
3) DOM (drawn over mandrel) round seamless tubing is made by cold drawing a tube through a solid steel mold (mandrel). In the process the OD and ID of the tubing is kept to much closer tolerance than hot rolled or electric welded tubing. There is no inner seam in seamless tubing. The drawing process also work hardens the surface of the tubing making it stronger. NASCAR still specs DOM.
4) Chromemoly (4130)  alloy contains some chrome and manganese. At the same strength level chromemoly weighs about 25% less than mild steel. Therefore chromemoly is the perfect choice where weight is a major concern like aircraft or auto racing. Chromemoly has a serious drawback for use in most metal fabrications, however. It is very brittle and can stress crack easily if not carefully TIG welded and stress relieved after welding. For most people  the weight savings is not important and they don't have the equipment or skills to use chromemoly.
2014 Jeep SRT
Offline muffintop
« Reply #2 on: January 08, 2010, 12:05:48 PM »
Oh ya... Russel Metals should have what ya need.
http://www.russelmetals.com/english/service/products/index.html
2014 Jeep SRT
Offline Elsifer
« Reply #3 on: January 08, 2010, 08:00:17 PM »
I would stay away from bending ERW. The seam can crack/break during and after bending. And the seam is the weakest point.
It can be done, but I wouldn't. And for what you are looking to do. 1x 20ft length of 1 3/4" .120 wall DOM should be enough.
Unless you make a few trophy's!
VA6CPL
Jeepless....
Offline mike s
  • Good times!
« Reply #4 on: January 12, 2010, 12:45:45 PM »
I've had really good luck with the guys at Metal Supermarket. Been in a few times looking for odd hunks and they'll happily let you go through their short cut off bins to find what you need and sell it by weight.
oldEnuff2NObetter
