Author Topic: jeep tj stalling  (Read 6509 times)
Offline 2grand4u
jeep tj stalling
« on: February 16, 2010, 06:47:40 PM »
i have a 97 jeep tj with a 2.5 and i can only drive for  a couple min befor shy bogs then drops to about 100 rpm then just stalls, if i wait 5 min it fires write up and gose for another minute or so. made for a very interesting ride from wiperious(spelt wrong but to lazy to fix) monday.
thxx Ryan
Re: jeep tj stalling
« Reply #1 on: February 16, 2010, 07:43:40 PM »
Crank positioning sensor?
Spell check is your friend.
Offline 2grand4u
« Reply #2 on: February 16, 2010, 08:46:08 PM »
i think i'm going to try the cps and the cts and see what happens
« Reply #3 on: February 16, 2010, 09:30:21 PM »
pull your codes first ryan.  throwing sensors at it will be expensive.  see what the code says first then go from there.  try the key three turn trick first.
if it were you CPS it would crank then die right away.......
Offline jonny5
« Reply #4 on: February 17, 2010, 12:42:03 PM »
Fuel filter? Not enough flow.
Is it that kind of feeling?
Offline 2grand4u
« Reply #5 on: February 17, 2010, 04:11:45 PM »
it's not trowing any codes Johnny, and it could be the fuel pump but i need to start eliminating thing so i can find the problem
Offline 4Banger_madness
« Reply #6 on: February 17, 2010, 07:13:38 PM »
test fuel pressure and test the sensors before u change them
Offline 2grand4u
« Reply #7 on: February 17, 2010, 07:31:04 PM »
how do you test the sensor?
« Reply #8 on: February 17, 2010, 07:39:08 PM »
im sure theres test procedures from mithchel or aldata let me check
« Reply #9 on: February 17, 2010, 07:46:17 PM »
cant get on it right now ill try at work in the am
Offline apex
« Reply #10 on: February 17, 2010, 09:49:38 PM »
I had a similar symptom. Turned out to be my starter. Something to consider.
Offline rangerdanger
« Reply #11 on: February 18, 2010, 11:40:06 AM »
Sounds like a lack of fuel, either a weak pump or clogged filter, my 97 jimmy had the same symptoms and a new pump/filter solved the trouble.
Lethbridge Coulee Kruzer
« Reply #12 on: February 18, 2010, 11:52:03 AM »
Did you move your fuel cell into the back of your rig?  I remember you posting something about that a while ago...
Offline 2grand4u
« Reply #13 on: February 18, 2010, 04:26:17 PM »
ya i did but i never had any problems
oh and i forgot to add it started acting up after i washed the engine compartment (i stayed away from the computer)
Offline 2grand4u
« Reply #14 on: February 18, 2010, 04:27:46 PM »
i hope it's not the pump because i doubt jeepstuff is warrenting the things they sell after they closed
