Author Topic: how to increase 06 Rubicon airlocker speed ?  (Read 1596 times)
jenny
« on: March 12, 2010, 01:52:13 PM »
Hi,
I have an 06 Rubicon with factory Dana 44 airlockers. I am not very happy with the speed of activation and disconnection.   Anyone figure out to improve this?  I also do not get the solid light on the toggle while having the front lockers engaged.  Just continuously flashes after I engage them with the switch.  Any ideas?
Re: how to increase 06 Rubicon airlocker speed ?
« Reply #1 on: March 12, 2010, 02:29:29 PM »
The only way i know is to put in ARB air lockers instead.
But, what i usually did was move back and forth from 1st to reverse and back to 1st to engage/disengage quicker.
« Last Edit: March 12, 2010, 02:32:13 PM by Spinalguy »
Offline LEMON-AID JAY
  • Bad a$$ zj owner
« Reply #2 on: March 12, 2010, 04:20:14 PM »
Hi,
The flashing light may mean there is a fault with that locker or switch. do you know for sure if the locker engages.
E-mortal customs
Www.e-mortalcustoms.com
3-2808 Ogden road s.e.
E-mail. [email protected]
Phone 403-265-6669
E-mail @ [email protected]
for all your 4x4 needs
www.piratesof4x4.com
Offline dac
« Reply #3 on: March 12, 2010, 04:23:26 PM »
Do you mean you only try and engauge the front one?  I don't have lockers so I'm guessing here but I thought I heard the front will only engauge if the back is on.
« Reply #4 on: March 12, 2010, 06:22:21 PM »
the front will only engage if the back is engaged .. as for speed if your using your lockers you shouldnt be in a rush since your in 4low
be patient thats all i have for you
« Reply #5 on: March 13, 2010, 11:10:28 AM »
The flashing light is not a good indicator of whether or not the locker is actually locked.
If its a functioning locker then locking is almost instant.
Ignore the light.
Offline parabs
« Reply #6 on: March 13, 2010, 10:42:53 PM »
I "heard from a guy who used to have am 03 rubi" (so take this for what it is worth) that you can make a modification to the switch to engage the locker in 4-hi and run at any speed, although the higher the speed, the more likely you could break something...
not sure if it true or bs.
2000 TJ Sahara - Sold
« Reply #7 on: March 13, 2010, 10:56:36 PM »
it is true, you can remove the safety but likely to blow the diff apart afterwards if you make a single mistake.
Offline Sugarphreak
« Reply #8 on: March 16, 2010, 12:11:51 PM »
If it is anything like mine (also stock OEM lockers) then the flashing light means it is either attmepting, waiting or in the process of locking it
For mine to lock I have to have to be in low range, stopped with the clutch in; not sure if Jeep is the same.
I wanted a Jeep... but the wife gave me a Hummer!
