Author Topic: On board air without tank?  (Read 3997 times)
Re: On board air without tank?
« Reply #15 on: April 12, 2010, 04:20:16 PM »
I'll throw this option in the mix.  I'm currently running  this setup without an air tank strictly to air up my tires.
Extreme-Aire Magnum
more info:
http://www.extremeoutback.com/index.cgi?cart_id=1877287.2841&pid=114
# Continuous Duty Cycle @ 150psi
# 1.5 Horsepower Motor 12 Volt (Available in 24 volt)
# 95 Amp Draw at 100psi
# 6 cfm free flow rate
# 2.6cfm @ 100psi
# 150psi max working pressure
# 16" long 6" wide 10" tall
Answer your phone ohmo :P
Offline Tagg
« Reply #16 on: April 12, 2010, 05:53:34 PM »
Thanks for all the input.  Some great compressors out there.  Keeping the budget in mind it I'm leaning towards the ARB High output compressor.  Northridge has the compressor, hose kit , and mounting bracket for $325 and thats about my budget.  For the wear I'm going to give it, it should last reasonably well.  And the tank/chamber on it is small and compact. Does that make sense?
08 Rubicon
