Author Topic: YJ exhaust leak drove me nuts  (Read 2902 times)
« on: May 13, 2010, 08:19:28 AM »
i think its coming out of the exhaust donut on the manifold.  i don't think the manifold itself is cracked;  can't see a crack, i think the compression fitting on the exhaust is just not sealing.
any ideas on how to get it super tight?  can i use that exhaust sealer crap from canadian tire or what?
« Last Edit: May 20, 2010, 08:34:51 AM by 01sahara »
Offline Pookapotamus
Re: YJ exhaust leak driving me nuts
« Reply #1 on: May 13, 2010, 08:50:11 AM »
get a new dounut and tighten the snot out of it!
« Reply #2 on: May 13, 2010, 09:02:33 AM »
hi ho, hi ho, off to NAPA i go!
if i break a stud off pook i'm stealing your exhaust manifold ;)
Offline WagoneerXJ
  • Bagon Wagon!
« Reply #3 on: May 13, 2010, 12:03:24 PM »
Didn't think 4.0's used exhaust donuts. Just ball/socket type flanges like Fords...?
84 Mustang GT-Built 351W 5spd
« Reply #4 on: May 13, 2010, 12:28:36 PM »
don't know. the manifolds on an XJ engine and the exhaust is the YJ exhaust.  it bolts right up but its still leaking. i don't see a crack in the manifold.  will do more investigating tonight i guess.
http://www.4wd.com/productdetails.aspx?partID=5570
found this. might run to autovalue and get one and replace it.  whats the worst that can happen?
« Last Edit: May 13, 2010, 12:53:58 PM by JOhnnyC »
« Reply #5 on: May 13, 2010, 04:54:18 PM »
we talked about this last night .... you know where I live
« Reply #6 on: May 13, 2010, 05:00:08 PM »
Johnny, why are you troubling yourself with such a minor thing.  You need to take your Jeep to a muffler shop and get a whole new exhaust built from the flange back.  Run the exhaust in front of the oil pan like the newer models, ditch the cat and run a 2.5" dynamax super turbo muffler and call it a day  ;D
« Reply #7 on: May 13, 2010, 08:09:29 PM »
scott you make a good point ;)
put a new donut on. the old one was icky.  can still smell traces of exhaust.
Dom. what you up to tomorrow? maybe i'll come by.... anytime :)
Offline mike s
  • Good times!
« Reply #8 on: May 17, 2010, 07:41:45 AM »
Ultra-copper silicone is the best for sealing exhaust surfaces, made by Permatex i think. It's just a high temp silicone that's supposed to be sensor safe. Used it on machined manifolds on V8's with no gasket at all, lasted years so far.
oldEnuff2NObetter
but still can't help myself
« Reply #9 on: May 18, 2010, 09:11:44 PM »
hmmm.......
to update. manifold is not cracked. its comin out the donut still.   i still just don't know why it won't seal.  i'm debating something like the silicon or that exhaust sealer stuff.
drivin me bonkers
and no its not comin in the back window/  theres no doors/roof on the jeep and its still bad.
« Last Edit: May 18, 2010, 10:38:54 PM by JOhnnyC »
« Reply #10 on: May 19, 2010, 07:27:32 AM »
hmmm.......
drivin me bonkers
 ::) ::) I already told you the solution Johnny  ;D
« Reply #11 on: May 20, 2010, 08:28:02 AM »
you might be right..........
i lathered it up with the copper silicone RTV yesterday and it didnt' do nothing. starting to think the downpipe is fubared or something.........
scott i'm already pricing ehaust from the manifold back ;)  i'm thinkin a big stack through the back ;)
Offline dac
Re: YJ exhaust leak drove me nuts
« Reply #12 on: May 20, 2010, 09:02:47 AM »
This picture was taken in my back yard and doctored to display what John should do for exhaust.  Needs a bigger hole in the hood or no hood at all.......
« Reply #13 on: May 26, 2010, 09:13:09 PM »
so. figured i'd update this instead of make a for sale add (cause i'm almost at that point)
siliconed the donut and patched at the cat.  kinda smell exhaust still. specially with the roof on.  with roof/doors/back window all done up its not bad at all.
tonight i ran some seafoam through it again.  and presto! no leaks! at least that i could see.
so how can i still smell exhaust??????????
goin into the shop tomorrow.  hopin for answers :(
« Reply #14 on: May 27, 2010, 07:31:27 AM »
I had problems with mine that with the soft top on and if the back window was up or not all the way down, I would get a very bad exhaust smell coming back into the heep.  I never did figure it out but it is gone now
