Author Topic: Electric Fan  (Read 1757 times)
Offline Aspirated
Electric Fan
« on: May 25, 2010, 08:50:30 AM »
So, am going to rig a bigger fan then stock into my 91 wrangler. Anyone have any kit suggestions?
1998 XJ
2008 KK
Offline Bigg Rudd
Re: Electric Fan
« Reply #1 on: May 25, 2010, 09:49:19 AM »
'95 Ford Tarus. Lots of info if you Google it.
Offline Aspirated
Re: Electric Fan
« Reply #2 on: May 25, 2010, 04:02:24 PM »
Great suggestion - thanks going to do that next!
1998 XJ
2008 KK
Re: Electric Fan
« Reply #3 on: May 25, 2010, 05:07:38 PM »
flex-a-lite.
Offline OffRoadNewbie
  • I Blame Keith !!
Re: Electric Fan
« Reply #4 on: May 25, 2010, 07:48:08 PM »
flex-a-lite.
i tryed 2 flex a lite fans both worked GREAT on the road ........ the first one lasted 3 hours on the trail the second 1 hour  >:(  maybe differnt for others but thats my experince
2006 TJ its Green !! ;)
Offline dontask
Re: Electric Fan
« Reply #5 on: May 25, 2010, 08:09:10 PM »
X2 on the ford taurus with the 6 cyl.
Easy one to find online and i think they have lots at pick n pull
Re: Electric Fan
« Reply #6 on: May 25, 2010, 08:45:56 PM »
flex a lit bolts rite in, sure its a pricey unit but works much better. ive had mine for6 years of daily driving, winter and summer, packed with mud, snow, and all sorts. even after the control box was full of mud i pulled it apart and cleaned it up, worked fine.
i think what you mean is that it worked great on the road, then it failed within 1 hour after packing it with mud. thats my guess.
Re: Electric Fan
« Reply #7 on: May 25, 2010, 11:51:55 PM »
I'm with Eric on the use of Flexalite fans. My CJ had a pusher, and a puller on it. I abused the heck out of it , and it still worked after five years without so much as a whimper.(uber expensive though)  I've also had a modicum of success with the Taurus fan as well, and they are readily available at junkyards for cheap. Do some research as CFM varies over the years, and some modifications will have to be done to make it work for your application.
Good luck with whatever route you choose!
« Last Edit: May 26, 2010, 12:08:00 AM by tubby89 »
  • I Blame Keith !!
Re: Electric Fan
« Reply #8 on: May 26, 2010, 06:31:32 AM »
i had mine hooked to a switch to shut it off when crossing water or mud still it craped out .........that being said i have read 100s of reviews about how well they work for " years " !!!  as said above its just my experience  :-\
Re: Electric Fan
« Reply #9 on: May 26, 2010, 09:36:25 AM »
How much is a flex lite system?
How much is the Taurus?
i have heard nothing but good things regarding the Taurus system.
Offline Bigg Rudd
Re: Electric Fan
« Reply #10 on: May 26, 2010, 10:05:14 AM »
Flex-A-Lite $300.00
Tarus $13.00
Do the math
Re: Electric Fan
« Reply #11 on: May 26, 2010, 10:53:56 AM »
The taurus is a little over 100$ to set up including the relay, switch, solenoid, and wiring required to run one reliably.
All electrics are inferior to mechanicals when it comes to moving air, but if you need to use an electric, the taurus is the more sensible way to go. Grab a few from the boneyard, and throw one in. keep the others for spares.
That said, I recommend staying with a mechanical clutch fan unless you absolutely cant.
Offline Aspirated
Re: Electric Fan
« Reply #12 on: May 26, 2010, 10:54:30 AM »
Im going to do the ford 3.8l fan swap, ill let you know how install goes and how it works after.
1998 XJ
2008 KK
