Author Topic: YJ front end clunk  (Read 4213 times)
Re: YJ front end clunk/creek
« Reply #15 on: August 08, 2010, 08:28:55 PM »
so to update,  sound is back, WD40 obviously isn't the solution.
sound happens when going down the driveway/bump with the wheel turned.  jumping on the front bumper it makes no sound, but rocking it back and forth its real loud........  totally weird.  does it in 2x4 and 4x4............. oye
thinkin it might be steering related now or something.................... to repeat, oye
« Last Edit: August 08, 2010, 09:12:02 PM by JOhnnyC »
Offline Shearcon79
« Reply #16 on: August 08, 2010, 10:03:27 PM »
WD = Water Displacement....not a lubricant.  Works good for temporary lube but nothing else.  In the end it will dry up and TADA!! your squeak is back.
Green 94 4.0 YJ :
4.5" RE Extreme Duty
Tera-flex Super Short SYE
Drive Products CV Driveshaft
« Reply #17 on: August 08, 2010, 10:04:52 PM »
Joey, that is what I tried to tell him...
« Reply #18 on: August 09, 2010, 08:37:24 AM »
if it were a squeek i wouldn't care ;)  it feels like somethings grinding itself down.
we'll see what the boys at modern think today.
Offline Shearcon79
« Reply #19 on: August 09, 2010, 08:07:28 PM »
Have you considered Broken Axle?
Green 94 4.0 YJ :
« Reply #20 on: August 09, 2010, 10:29:07 PM »
tightened the ubolts (they were mega loose)  that fixed it.  now its just regular YJ noises again ;)
also, played around with the CAD, swapped the old axleshaft back in, and lubed my brake caliper sliders.  think its good.  just stickin with the regular shafts for now; will consider chromos in the future if i keep that axle.........
Offline apeman
  • not as grumpy
« Reply #21 on: August 10, 2010, 12:40:46 PM »
use a second layer of carpeting in the yj and problem solved...works for driveline vibes also.
Getting grumpier every day.
