Author Topic: 4.0l power loss, decrease in mileage, black smoke/soot  (Read 1316 times)
Offline parabs
« on: October 09, 2010, 01:30:53 PM »
Over the last couple weeks, I developed what seemed like intermittent power loss, and last night it was confirmed.  I drove 800kms, stopped for about 2 hrs, then came from med hat to calgary ~280kms.
I couldnt go over 110 in top gear, I had to press on the pedal to maintain speed going down hills, ie the hill by Gleichen (sp?) and I burnt 60l in a trip that I usually burn much less.
Im going to change out the plugs, im not getting the check engine light, and I checked the codes with my own personal reader and got nothing.
Maybe O2 sensor?
Your thoughts?
Thx in advance. ;)
2000 TJ Sahara - Sold
Offline Justink
  • '89 comanche 5'' lift, 33's
Re: 4.0l power loss, decrease in mileage, black smoke/soot
« Reply #1 on: October 09, 2010, 05:59:49 PM »
Map sensor? That caused me to blow black smoke and I had a major power gain when  I replaced it.
'91 cherokee 4.5'' 31's DD
'88 Nissan 300zx just for fun
Offline parabs
« Reply #2 on: October 09, 2010, 07:49:34 PM »
I changed the plugs, no noticeable change.
I read on jeepforum.com, and then I disconnected the upstream o2 sensor, and it is working pretty good now, so I am going to change it out tomorrow.
If the problem recurs, I will have to look deeper into the map sensor..
Offline Krisman
« Reply #3 on: October 14, 2010, 10:30:19 PM »
im not sure what kind of scanners autovalue has, but maybe give that a shot. they let you use them for free i believe.  the snapon ones will show you voltages, you can check o2 cycle voltage
97 tj 4.0 35's
98 grand 5.2 33's
93 grand 5.2 37's - sold
« Reply #4 on: October 15, 2010, 05:53:09 PM »
catalytic converter could be starting to plug up. try the O2 sensor, then try cat con.
Offline parabs
« Reply #5 on: October 18, 2010, 09:32:05 AM »
turns out it doesnt seem to be the O2 sensor.  I changed out the TPS and now it is running much better...but I wont know if it is fixed until I run a couple tanks through it..
I didnt think of the cats Eric, do you know if you gut/cut out a cat will the computer throw codes??
« Reply #6 on: October 18, 2010, 07:49:32 PM »
it could throw a code as the downstream O2 isnt getting the reading it should. but ive seen some that didnt really care after the cat was removed. so it may be worth a shot.
Offline WagoneerXJ
  • Bagon Wagon!
« Reply #7 on: October 18, 2010, 08:59:40 PM »
there are ways to fool that downstream O2 sensor. cheap too........ I have the one on my gf's TJ fooled for months now :)
84 Mustang GT-Built 351W 5spd
