Author Topic: Why The heck is my tire going flat!  (Read 6707 times)
Re: Why The Heck is my tire going flat!
« Reply #15 on: January 11, 2011, 11:35:26 AM »
Valve core itself, either a little ice in there or the o-rings shot. It would seat somewhat but if you bumped the needle it would leak again.
Best part is after spending 30 min getting the stupid thing to seat the tire place is just gonna pop the bead again to put a new stem in! Hahaha oh well.
« Last Edit: March 16, 2011, 12:55:18 PM by specialk »
Offline AV.NINE
Re: Why The heck is my tire going flat!
« Reply #16 on: January 11, 2011, 12:35:52 PM »
Av.nine for the win!!
« Last Edit: March 16, 2011, 02:58:14 PM by frenchy »
« Reply #17 on: January 11, 2011, 04:29:21 PM »
Please see myself or Kyle for your prize. It's yellow and says we owe $115 to CPS.
« Last Edit: March 16, 2011, 02:57:59 PM by frenchy »
Offline AV.NINE
« Reply #18 on: January 11, 2011, 05:13:34 PM »
Ill donate my prize to johnnyc.
I have enough of those already. Don't want to be greedy.
« Last Edit: March 16, 2011, 02:57:48 PM by frenchy »
« Reply #19 on: January 11, 2011, 06:35:05 PM »
:'( thanks Justin, but i don't need any gifts. you should give it to someone else that is deserving, perhaps Trevor ;)
« Last Edit: March 16, 2011, 02:57:35 PM by frenchy »
« Reply #20 on: January 11, 2011, 06:43:13 PM »
Trevor doesn't deserve anything extra. He still has the goats.
« Last Edit: March 16, 2011, 02:57:21 PM by frenchy »
Offline FirstTimer
  • Gettin there!
« Reply #21 on: January 11, 2011, 09:55:37 PM »
Av.nine you were close but close doesn't get you a win! It is the valve core, not the valve stem!
  what a night jason! We'll have to meet under better circumstances next time! Hopefully, it won't involve a tire and a uturn ticket x2! Thanks for your help again!
On another note where do I get a valve stem core? im pretty sure the small the needle is bent our something...
« Last Edit: March 16, 2011, 02:57:11 PM by frenchy »
« Reply #22 on: January 11, 2011, 10:29:37 PM »
I already got my prize Sept Long.... from the Mole lady's buddy....
« Last Edit: March 16, 2011, 02:57:02 PM by frenchy »
Offline Zombie
  • Jeff the Zombie Jeep
« Reply #23 on: January 11, 2011, 10:58:59 PM »
I know you can get them from princess auto, or you could drop by my work and ask for steve, if you bring the tire I can swap the core out for you, its like a 2 second job.
NE costco tire shop. I would think most shops would swap a core for you if you asked them to. the core costs like a penny.
« Last Edit: March 16, 2011, 02:56:52 PM by frenchy »
Offline AV.NINE
« Reply #24 on: January 12, 2011, 05:11:34 AM »
Well the valve cores are part of the valve stem. Its pretty obvious that if 2 or more tires are leaking bad it has something to do with valve stems.
« Last Edit: March 16, 2011, 02:56:38 PM by frenchy »
Offline T-bomb
« Reply #25 on: March 16, 2011, 12:11:57 PM »
Had a 99TJ same issue and the rim was corroded where the weight was mounted.  remove, wire brush, mount and balance.
« Last Edit: March 16, 2011, 02:56:13 PM by frenchy »
« Reply #26 on: March 16, 2011, 12:32:26 PM »
All of my tires have gone flat intermittently , no schedule , rhyme or reason. Just changed the last valve in the tire stem yesterday morning when the tire was flat . Last time you got tires did the installer complain and grind of the mud residue with a wire brush grinder on the inside of the rim where the tire seats ?
« Last Edit: March 16, 2011, 02:55:49 PM by frenchy »
