Author Topic: Axle ratio with 35s  (Read 5496 times)
Re: Axle ratio with 35s
« Reply #15 on: January 24, 2011, 06:03:10 PM »
gears + setup kit is usually around $300 per diff ($600)
labour would prob be $300 or $400 per diff.  more or less depending on if and type of locker intalled etc.  ie.  ARB may run $500 for first diff and $400 for second..  detroits or spools probably cheaper.
that's about what I would expect to pay someone.  some may be more, some less.
Offline slimbeam
« Reply #16 on: January 24, 2011, 07:34:27 PM »
Ive had 3.55 with my 35's for a number of years with my 4.2 and did ok, 4.56 is whats in her now and is better for climbing and 5th gear is used again
« Reply #17 on: January 24, 2011, 11:37:49 PM »
with a good choose or tools and some common sense and the internet  a person can do anything
but if you dont feel adventurous then you will be spending probably 400- 500 per diff to have gears installed plus the cost of gears and the install kit
Offline AstraX
« Reply #18 on: January 24, 2011, 11:45:05 PM »
well some day I might feel adventurous but for now my jeep is still under warranty so if I did do anything to it in the short term it will likely be done by licensed mechanics.  Though I don't know how much of a difference that makes when it comes to warranties.
Offline Canuck Bob
« Reply #19 on: January 31, 2011, 06:01:39 PM »
« Reply #20 on: January 31, 2011, 07:05:12 PM »
thats an awesome ratio chart .. one problem   with it is   it doesnt take in consideration for the engine .. 4 banger or 4.0 L    or the few people that are running hemi's
but besdies that its a good chart
Offline allanbr
« Reply #21 on: February 01, 2011, 10:19:35 AM »
Kermit, if you want, I can send you an Excel spreadsheet that you can plug in various trans - T-case, axle ratios and tire sizes and then see the final gear ratios of each. It also shows the vehicle speed @ various engine RPM's and also RPM's @ 110kph for the top three gears.  I'd post it on here, but unfortunately, I'm not tech savvy that way.  I'm pretty sure I could attach it to a PM though.
Let me know - I've found it useful for deciding on future parts purchases.
'12 Rubicon Unlimited  (3.5" AEV dualsport lift, 35" Duratracs, AEV front & rear bumpers, Warn 9.5ti winch )
Offline Kermit
« Reply #22 on: February 01, 2011, 05:40:11 PM »
Yes please.. PM sent
« Reply #23 on: February 02, 2011, 07:29:49 AM »
Here is the spreadsheet.
