Author Topic: Water Pump and...  (Read 1121 times)
Offline Traktor
Water Pump and...
« on: March 03, 2011, 04:41:34 PM »
I need to change the water pump on my 4.0 YJ. I could hear the bearings howling occasionally and now the fan is wobbly. I know I need to change the pump but I'm unsure what else, my crappy Haynes doesn't explain it very well. Do I also have to change the fan clutch? Or is the shaft on the new pump enough to solve that issue?
Also, is there anything else I should do while I'm in there?
1995 Cherokee Country (Kaw-liga) - Way too much chrome, but just enough red.
Re: Water Pump and...
« Reply #1 on: March 04, 2011, 07:21:27 AM »
The water pump is pretty easy, but you have just to remove a lot of stuff to get at it.  As for the clutch fan, does the fan spin freely with the engine off?  If it does not spin then it is time for a new one
Offline Traktor
« Reply #2 on: March 04, 2011, 08:40:34 AM »
It seems like the clutch and everything is working properly, it's just the wobbley fan that I want to make sure is fixed. Will that be repaired once I put the new water pump in? I guess what I'm asking is, does the shaft on the new water pump fit into the fan and clutch and resolve any wobbley issues?
Thanks for the reply,
Tim
Offline fug
  • Airdrie Pick n Pull
« Reply #3 on: March 04, 2011, 09:25:28 AM »
Yep... a new pump should take care of the play in the shaft you are seeing.
Fug
TJ Rubicon
Offline Traktor
« Reply #4 on: March 04, 2011, 11:27:04 AM »
Good news. Thanks guys.
