Author Topic: Sweet M101 for the Fox - HUGE THANKS to Jeff  (Read 7997 times)
Offline Unknown303
Re: Sweet M101 for the Fox - HUGE THANKS to Jeff
« Reply #15 on: March 10, 2011, 06:46:52 AM »
Makes me wish I jumped on that trailer when he was offering to bring it back...  :(
Offline JJonesee
« Reply #16 on: March 28, 2011, 09:52:48 PM »
I think what you are referring to is the M10o which is a 1/4 ton version of the M101.  The M101 has a 3/4 ton capacity at 1,700 lbs and is heavier than the US equivalent M100.  After more searching the M101 appears to run ~700 lbs dry and empty which would make more sense based n the towing "feel" and Jeff's comments on hauling it from the Peg.  It  is likely higher than 700 and definitely not 575 lbs.  I will hits the scales here soon and get an actual weight.
Heres the US M101
http://olive-drab.com/idphoto/id_photos_m101_trailer.php
I knew they were armored up but dang - 125 lbs worth?
06' Rubicon LJ
52' M-100
82' Scrambler x 3
