Author Topic: Time to Re-Gear  (Read 7159 times)
Re: Time to Re-Gear
« Reply #15 on: March 31, 2011, 11:30:31 PM »
Also have seen many ARBs fail due to broken lines
ARB makes a repair kit that has a coupler and a few feet of line if you manage to damage it. Took me five minutes to repair mine with this kit, or you could go to Walmart's aquarium section and find a coupler that matches the ARB's plastic line diameter. Careful routing and use of zip-ties also helps.
Offline apeman
  • not as grumpy
Re: Time to Re-Gear
« Reply #16 on: April 01, 2011, 12:39:32 AM »
I will be going the elocker route on my d30...after seeing a chunk of ice the size of a golf ball disable an ARB... ::)
Getting grumpier every day.
Re: Time to Re-Gear
« Reply #17 on: April 01, 2011, 01:27:07 AM »
I don't have an ARB so I don't have to worry but next time one breaks on the trail I'll suggest that to the owner. ;)
Re: Time to Re-Gear
« Reply #18 on: April 01, 2011, 09:59:09 PM »
It was the size of a pie plate actually... :P
Offline Shearcon79
Re: Time to Re-Gear
« Reply #19 on: April 03, 2011, 09:26:21 PM »
So where are people picking up their gears sets these days.  There are a lot on ebay but all ship from the USA.  The prices vary and so does the product.  I have heard that YUKON is one of the best.  Another question...Is there a contact in Calgary for Northridge4x4? I think I remember meeting a guy at a show-n-shine a couple years back but no longer have his info...or is best just to go through the site?
Green 94 4.0 YJ :
4.5" RE Extreme Duty
Tera-flex Super Short SYE
Drive Products CV Driveshaft
Re: Time to Re-Gear
« Reply #20 on: April 03, 2011, 09:31:21 PM »
For local shops, Modern Motors and National 4x4 . For Northridge, just call Stan.
Stan is the man.
Again,
Stan.... Is the man.
Re: Time to Re-Gear
« Reply #21 on: April 04, 2011, 05:16:33 AM »
If yer google finger happens to be broken
www.northridge4x4.ca
And yes. Stan is the man. :)
Offline Jrama
Re: Time to Re-Gear
« Reply #22 on: April 04, 2011, 07:10:10 AM »
I am not the first to say this nor will I be the last, but ordering any major parts from a local shop is going run you nearly number double what Northridge will charge you.
As far as gears are concerned it is my understanding that most of them are all made in the same factory and then branded out. So when it came time for me to choose gears I just went with the cheaper set that Northridge sells. There are no failures or complaints going with the AlloyUSA gears
« Last Edit: April 13, 2011, 04:57:06 PM by Jrama »
Offline Jrama
Re: Time to Re-Gear
« Reply #23 on: April 13, 2011, 02:48:15 PM »
Anyone know if i could get away by just using the northridge install kit or do i need the overhaul. The big difference is the inclusion of carrier and pinion bearings? Keep in mind the e locker and the reuse of the dana 30 carrier
EDIT* well afteer looking into it, the only clear advantage I can tell is that I could use my old bearings for set up, other than that its not required. People seem to do the overhaul as a may as well type deal, and well it seems like a good idea
« Last Edit: April 13, 2011, 04:57:15 PM by Jrama »
Re: Time to Re-Gear
« Reply #24 on: April 15, 2011, 07:59:57 PM »
If you're going to regear you might as well rebuild the whole thing with brand new shiny things. No sense in having to pull everything back out later cause you toasted that used bearing.
Offline Marco
Re: Time to Re-Gear
« Reply #25 on: April 17, 2011, 12:22:34 PM »
What can a guy expect to pay for re-gearing? I didnt see anything in the thread. My 4:11 with 37" is retarded after reading this.
locked and loaded
Re: Time to Re-Gear
« Reply #26 on: April 17, 2011, 03:48:02 PM »
I believe the typical shop rate for just regearing would be 4-6 per axle and multiple that but your favourite shop's rates.
Offline THE GOLD DIIGGER
Re: Time to Re-Gear
« Reply #27 on: April 17, 2011, 04:44:35 PM »
Re-gearing is about $2700 with gears at a shop.
Offline Jrama
Re: Time to Re-Gear
« Reply #28 on: April 17, 2011, 06:11:04 PM »
I got a qoute from Chanda I was impressed with, you should go ahead and get qoute
Re: Time to Re-Gear
« Reply #29 on: April 22, 2011, 12:54:00 PM »
Mine are already there  ;D
