Author Topic: The thread where Jamie starts complaining and everyone else joins in...  (Read 9803 times)
PHHFFFTT!!!! Those will NEVER last! You would eat them before they rolled out of the garage.
Damn it!... you are so right...
Here goes my good gas milage
Offline mike s
  • Good times!
That looks so good. God I want bacon for diner...
oldEnuff2NObetter
but still can't help myself
There is nothing wrong with bacon for dinner. Just make sure that you apply a liberal layer of belt dressing to the pan before you start cooking.
Offline XJHERO
  • Soberphobic
So do i need to run any special gear oil additive in my rear d44 with a spool??  ;D
DD
Get at me Wolf
The banana Peel I threw in there is good enough
Offline Justink
  • '89 comanche 5'' lift, 33's
Say I ran my jeep out of blinker fluid, would belt dressing be similar enough I could use it?  :D
'91 cherokee 4.5'' 31's DD
'88 Nissan 300zx just for fun
If your blinkers are squeaking instead of clicking then yes! W Squared once told me that belt dressing also quiets the squeak between his thighs when hes wheeling in his latex rubber pants... Never seen it, just have to go on his word tho...
Offline comanche killer
  • Aaron
hey would a banana peel work for my welded  rear  d44  or is the banana peel only for spools  :)
« Last Edit: July 01, 2011, 05:04:24 PM by comanche runner »
95 3/4 ton Chev  dailydriver/heavy hauler
97 green MZJ custom 4link rear/3link front, FF 14 bolt rear welded, D 60 front, ax-15, np-231,custom rollcage, half doors, PSC hydro assist 14"kings 40"boggers
I told you that in confidence, you sneaky person! I never would have revealed it if you hadn't had so many issues with noises while wheeling in your arseless naugahyde chaps.
Offline rws
  • Stump Grinder
You guys are all clueless!
Three pages of dribble and no one has mentioned that the only belt dressing worth getting is the one with zinc additive.
