Author Topic: July 3 2011 run Waiparous  (Read 10394 times)
Offline Delco21
Re: July 3 2011 run Waiparous
« Reply #15 on: June 28, 2011, 05:51:43 PM »
I have a 9000lb winch, shovel, work gloves and tools.
No recovery strap yet though
Zombie outbreak response unit
« Reply #16 on: June 28, 2011, 07:12:55 PM »
If you have a winch, you will want a tree saver and d-ring to go with it. You don't want to end up wrapping that winch cable around a tree.
Offline Bone206
« Reply #17 on: June 28, 2011, 07:26:53 PM »
snatch blocks are nice too.  ;D
Offline Delco21
« Reply #18 on: June 28, 2011, 07:35:55 PM »
Were do I get a tree saver? What is a snatch block for? I've heard people mention them before
Offline THE GOLD DIIGGER
« Reply #19 on: June 28, 2011, 07:40:23 PM »
Modern motor just off blackfoot they stock all the stuff there.
« Reply #20 on: June 28, 2011, 07:44:57 PM »
A snatch block allows you to make a stronger pull over a shorter distance using mechanical advantage. It's not vital that you have ont, but you'll eventually want one for your winch.
The tree saver and a clevis (d-ring) is a must-have. That's how you attach your winch line to your anchor point. Like 37sandrunning said, Modern Motors on Blackfoot carries them at a very good price.
Offline newfie glass
« Reply #21 on: June 28, 2011, 08:40:12 PM »
if i get my steering box replaced and hooks mounted i will be in. stupid work always getting in the way :P
Quality Paintless dent repair
403-807-1042
Offline Bone206
« Reply #22 on: June 28, 2011, 09:05:14 PM »
Snatch blocks can also change the direction of your pull with a snatch block. Basically think of it like a pully that you can winch around corners with, or hook up to yourself to increase the mechanical advantage of your pull as W Squared said.
Offline rosko
« Reply #23 on: June 28, 2011, 09:12:09 PM »
Tied up this weekend, but was out there on Saturday. Run to the falls was great and surprisingly dry. The river crossings are the lowest I've seen too.
Have fun!
Teraflex Tummy Tuck
Offline Ostego
  • Full Size Jeep
« Reply #24 on: June 29, 2011, 07:38:55 AM »
I will be out in the bush already by then, look for the old j20 I may join the trek if I see you.
« Reply #25 on: July 02, 2011, 02:31:04 PM »
Still on, weather looks beautiful ;D
 Meeting at Smitty's at 9AM, leave by 9:30AM.
Channel 10 on the CB, I'll have a white Grand Cherokee on 33's
Offline Delco21
« Reply #26 on: July 02, 2011, 03:26:27 PM »
Were is the smittys? Haven't been out there much
RUBICON13
« Reply #27 on: July 02, 2011, 03:52:28 PM »
Sounds good.
I will be in a light green 2007 Wrangler Unlimited (4 door) Rubicon (stock).
You can see Smitty's from Highway 22 on the left (west)  as you drive north into Cochrane. It is south of Hwy 1A.
See you guys tomorrow. I will probably arrive early at Smitty's and have breakfast before we head out. So, if anyone else wants to show up early and eat look for my Jeep and I am 6' 2" tall and will be in a long sleeve black shirt and black cargo pants.
Looking forward to the fun and learning!
Jeff
« Reply #28 on: July 03, 2011, 09:13:51 PM »
Just got home, what a day :o
Thanks to everyone who stopped when I had the death wobble and to Jason especially for his side of the road fix and his unstoppable winch.
If anyone has any, could I get some pics?  [email protected]
« Reply #29 on: July 03, 2011, 09:44:13 PM »
did he install a new trackbar for you?  one without an inch of play?
