Author Topic: Drive Shaft  (Read 1287 times)
Offline Yellow RUBI
Drive Shaft
« on: July 08, 2011, 12:38:35 AM »
So when adding lift to your Jeep at what point is it that the drive shaft is needs to be Lengthened? Is it simply a case of being to short to fit or might it still bolt up but end up binding when flexing?
If the latter is the case,  is there a way to check when the Jeep is on the jack stands?
Take a Compass!
Re: Drive Shaft
« Reply #1 on: July 08, 2011, 09:47:38 AM »
Usually around 3.5", but it always varies depending on your lift. The longer shafts are meant to work in conjunction with a SYE (Slip Yoke Eliminator) which shortens the transfer case length and allows the longer shaft to fix your driveline angle. You can sometimes fix this by using a transfer case drop instead, or having adjustable control arms and changing the pinion angle.
All of this is to try to keep your drive shaft from binding as much and make your u-joints much happier.
