Author Topic: Some problems may or may not be a big deal dont know  (Read 7949 times)
Offline Raspberry
Re: Some problems may or may not be a big deal dont know
« Reply #15 on: September 19, 2011, 01:52:51 PM »
Sounds like the fan clutch might be shot and causing your overheating problem. Get it looked at ASAP.
That's the first thing that came to my mind also.
Offline Moezer
« Reply #16 on: September 19, 2011, 02:51:04 PM »
lession learned i guess, im washing the jeep from the inside at the momment, i changed the engine oil and its clean... how can i check the others? the diff and t case?
Offline Raspberry
« Reply #17 on: September 19, 2011, 03:23:47 PM »
With both the diffs and the tcase you must remove the fill-plug and pop your old-skool dip-stick (ie. finger) in there. If the fluid inside doesn't come up to the fill plug for you to be able to touch it, and you don't know how long its been running low, then its probably best you drain and re-fill with new fluid anyway.
Offline Moezer
« Reply #18 on: September 19, 2011, 09:45:40 PM »
cool thanks, the jeep seems to be running good at the momment, the engine oil is good as i just changed it like 2 days ago and i checked it to day its clean, the jeep doesnt smoke any kind of smoke from the muffler, tomm maybe ill check the t case and diffs .
Also engine fan/ clutch thingy have been changed
« Reply #19 on: September 19, 2011, 10:52:10 PM »
Rad cap changed yet or did you get a new one with the new rad?
Offline Moezer
« Reply #20 on: September 19, 2011, 11:15:53 PM »
i used the one from my old one but this one doesnt leak or anything and the seals on it look fiarly new
« Reply #21 on: September 19, 2011, 11:31:29 PM »
Also when you replaced the rad did you get a new rad cap? Having the wrong psi rated cap or an old cap that isn't venting properly can cause the rad to over pressure, and if its a plastic rad, to crack. Always put a new cap on a new plastic rad, or it will happen again.
If you won't heed the advice of others, why bother asking for it?
« Reply #22 on: September 20, 2011, 06:18:06 AM »
To paraphrase Trevor...if you ignore the advice given by people like Clay that really know their stuff...don't expect sympathy or even anyone bothering to give you more advice when things continue to go wrong.
Offline Moezer
« Reply #23 on: September 20, 2011, 06:37:45 AM »
lol im just saying :P ok will change it today
« Reply #24 on: September 20, 2011, 09:11:17 AM »
 :D
« Reply #25 on: September 20, 2011, 10:24:43 AM »
Sounds like a great plan! Hopefully it will all work out with no permanent harm done, and you'll be enjoying your TJ for years to come.
Offline Moezer
« Reply #26 on: September 20, 2011, 08:29:38 PM »
blah, i didnt get one today.... but i bought a brand new winch lol
Im not sure if i said this but the 2d time when i went in the deep water i didnt get stuck i got out right away, just a heads up for the water going in to my diffs and trans but will it have done damage for just 30 secs tell i got out the water do damaege?
« Reply #27 on: September 20, 2011, 08:56:28 PM »
As has been stated, change the diff fluids. When was the last time they were ever done? i faithfully did mine every 10k, sooner if i was in muddy waters often 8)
« Reply #28 on: September 20, 2011, 09:01:23 PM »
Hey, i just read that its a 2002. Unless you know the service history, changing all fluids would be advisable regardless of your last experiences.
When ever i buy used, i do all the fluids as soon as i get the vehicle. This includes a Toy diesel truck, Mits Pajero, Skyline, Dodge Ram.
The only one id did not do was the 77 jeep (except for oil change) as the owber had a detailed book on everything he did. He was very meticulous and trustworthy.
Offline Moezer
« Reply #29 on: September 20, 2011, 09:41:49 PM »
well i bought the jeep from a family that had the jeep since new but it was sold to other family members and was mostly on farm land, the lady did do all check ins on fulid and eery thing when i bought the jeep, but i did only change the engine oil
