Author Topic: When cold, engine is slow to reduce rev's when gas peddle released???  (Read 2691 times)
Offline crusty
Re: When cold, engine is slow to reduce rev's when gas peddle released???
« Reply #15 on: December 04, 2011, 06:42:08 AM »
OK, It's not the cable and a return spring doesn't help. I've cleaned the IAC and throttle body. Any other ideas would be appreciated.
Thanks.
Crusty
« Reply #16 on: December 04, 2011, 09:19:13 AM »
Vacuum leak somewhere
Offline heep-a-lop
  • EMF WHORE
« Reply #17 on: December 04, 2011, 09:28:58 AM »
yep can of intake cleaner and when it hesitates start looking in that area...  really sounds like a vacum leak
Offline crusty
« Reply #18 on: December 05, 2011, 05:52:35 PM »
Hi Heep a Lot. Thanks for the advice. Can you explain a little more on what you mean to find the vacuum leak? Sorry I don't understand the process.
Cheers.
Crusty
Offline heep-a-lop
  • EMF WHORE
« Reply #19 on: December 05, 2011, 07:23:40 PM »
basically u start the vechile take a can of intake cleaner or soemthign that will bog down the motor spray all vacum hose connections , lower intake manifold, anywhere untill u get a reaction from the engine then constentrate on that area for abit untill u find the leak most likely a bad rubber hose some where
« Reply #20 on: December 05, 2011, 08:28:25 PM »
Spell check is your friend...
