Author Topic: Proper Fitting Tire Chains  (Read 5164 times)
Re: Proper Fitting Tire Chains
« Reply #15 on: December 18, 2011, 12:42:02 AM »
I certainly appreciated the member  (Brian) who brought chains last year and kindly pulled several of us with lockers , 35s  and winches on more than one occasion.
I remember that.... fun times.
Tom, he did hit it with lots of skinny pedal, and with speed. The grade and the elements were against us that day. I can't remember if Bryan was running his chains that day, or not. We sure put his winch through a workout, though!
« Reply #16 on: December 18, 2011, 10:20:44 AM »
I guess it depends on how you wheel. Typically if I need to put chains on the break trail I take that as a good sign that maybe its time to turn back and try a different trail.
Usually when I pull out the chains is when I've broken something and am reduced to 2wd. Or I have to tow out a dead vehicle and there are lots of hills.
Offline JohnB
« Reply #17 on: December 18, 2011, 12:30:10 PM »
You really want to have 2 or 3 cams.  It just makes life so much easier.  If you shorten them right up, you will have a hell of a time putting them on in less than perfect conditions.  Without cams you will need to use bungies, but then you will always be losing bungies on the trail.
Anyway, I don't understand the hate for chains.  When it is icey, life is so much easier and safer.  They are quick and easy put on, should be less than 2 minutes and don't slow you down off road.  They cost less than the price of a tire for a pair.
« Last Edit: December 18, 2011, 12:32:02 PM by JohnB »
« Reply #18 on: December 18, 2011, 03:45:38 PM »
not a hate, just don't understand how we ever wheeled in winter without them. Anyways, sorry for the hi jack. Who am i to talk as i don't wheel anymore :laughing:
« Reply #19 on: December 18, 2011, 04:20:29 PM »
we've had a lot of fun with chains and without chains.  they even saved our bacon a few times.
Offline binare
« Reply #20 on: December 18, 2011, 04:39:40 PM »
Tirechains made of bacon... mmmm.
Offline JohnB
« Reply #21 on: December 18, 2011, 06:49:38 PM »
Just another tool in the arsenal.
I'm quite sure chains have been around a lot longer than recreational off road driving...
« Reply #22 on: December 19, 2011, 09:02:09 AM »
Back when waiporous was open you chose a trail that was right for the group. And some years there was so much snow you had to run chains just to do the waiporous valley road. Browns hill , first hill west of four corners was impassable with all the snow even with chains.
Now there is a limited selection of open winter trails so you choose the trail before you even get there. Most open winter trails all have steep hills and yes it is a safty factor if the run leader says who runs the jewellery.
And yes I have slide backwords down steep hills and sometimes not in the ruts. What a rush. Not for the newbie.
Offline slimbeam
« Reply #23 on: January 04, 2012, 06:56:04 PM »
Never say never Tom chains have there place, although never needing them on any trails in AB or BC but I have used them in northern SK and MB to get through when your up against bumper height snow and nowhere to winch to
