Author Topic: This is Good Right?  (Read 3038 times)
Offline rws
  • Stump Grinder
Re: This is Good Right?
« Reply #15 on: January 12, 2012, 02:59:48 PM »
Those gouges are not good but can be smoothed out with a piece of emery cloth.  They may have been caused by some previous owner pounding in the race with a misdirected blow.  When you install the new race use a race install tool or gently tap it in with a punch.
If you have time throw the race in the freezer overnight which will shrink it enough to make installation a bit easier.
The crush sleeve can take a massive amount of torque to crush.   As Clay said, proceed slowly because once it starts it can go real  quick.
« Last Edit: January 12, 2012, 03:09:28 PM by rws »
Offline Jrama
« Reply #16 on: January 12, 2012, 08:08:24 PM »
^^Funny the whole jeep is in a freezer, I used a torch to warm up the housing as the race did not want to go in. A little warmth and there were no more issues.
Alright so I got things set up and installed the carrier and used the marking compound to take a pattern and well..
Drive
Coast
Dang
« Last Edit: January 12, 2012, 08:16:30 PM by Jrama »
« Reply #17 on: January 12, 2012, 08:18:38 PM »
its pretty damn close .. hows the back lash
Offline Jrama
« Reply #18 on: January 12, 2012, 08:22:11 PM »
Right now I do not have a dial indicator or calipers (yet), I just did this because my rebuild kit came with marking compound  ;D
Looking at the chart patterns its seems to be off a bit? Is it usable?
Drive is a bit close to the root and in some section its *toe* bias
« Last Edit: January 12, 2012, 09:04:41 PM by Jrama »
« Reply #19 on: January 13, 2012, 08:58:32 PM »
Find out your backlash and get back to us. Cant comment much about it with out knowing the BS.
