Author Topic: Rear driveshaft vibe  (Read 6256 times)
Offline Knox
Re: Rear driveshaft vibe
« Reply #15 on: February 13, 2012, 08:41:46 AM »
where do you guys get the cv double cardans rebuilt?
2003 TJ
« Reply #16 on: February 13, 2012, 10:46:16 AM »
Try clocking it 180 to see if it changes at all. If it does, that definately would confirm your balance.
« Reply #17 on: February 13, 2012, 10:52:31 AM »
Pat's or DSI
« Reply #18 on: February 13, 2012, 01:12:08 PM »
In my garage  ;D
« Reply #19 on: February 13, 2012, 06:59:22 PM »
Danco. Right by the old DSI over by modern.
« Reply #20 on: February 13, 2012, 07:40:38 PM »
So I took the driveshaft back into Pat's this morning and they initially said my angles were wrong, the angle at the t-case must match the angle at the pinion to cancel each other out.
I disagreed and said anything I have ever seen with a double cardon joint had the pinion pointed straight in line with the shaft less a degree or so.
They agreed to double check the balance and it was off. Apparently the machine had been set up for a DS with a 4" tube and mine was 2-1/2".
I will get the shaft back in tonight but won't be able get it up to speed given the road conditions out here.
I'll report back after a road test.
Vince
« Reply #21 on: February 13, 2012, 08:35:08 PM »
That is where i go, Wherever Cory works is where i follow. Used to be next door at DSI, now at Danco.
« Reply #22 on: February 14, 2012, 10:03:15 AM »
Exactly. Cory is without a doubt one of the best driveline guys around, and he treats us better then those big shops.
« Reply #23 on: February 14, 2012, 01:58:37 PM »
Well that's good to know, right after I spend $600.00 at Pats :'(
Offline NUXJR
« Reply #24 on: February 14, 2012, 03:06:26 PM »
Yiup Cory da dude!!!!!!  He da one dat set-up the rear drive shaft for de ol XJ....only had to do it once, good to go!!! ;D
« Reply #25 on: February 14, 2012, 07:48:01 PM »
Re-balanced DS back in and ran it up to about 110kmh, vibes about 95% gone. I should be able to dial it in a bit better with the pinion angle.
Right now the pinion is 1 degree below the DS, should I be going up to a zero angle or down and increase the angle?
Vince
« Reply #26 on: February 14, 2012, 08:19:18 PM »
Down.  Increase the angle a bit.  U joints need to see some kind of angle for them to work properly
U want those needle bearings moving inside the caps when it  rotates if not ull just wear out the u joint by running on the same few needle bearings
« Last Edit: February 15, 2012, 12:05:53 PM by Rubi03 jef »
« Reply #27 on: February 14, 2012, 09:09:46 PM »
U want those middle bearings moving inside the caps when it  rotates if not ull just wear out the u joint by running on the same few middle bearings
Thanks Jeff, I'll play around with it tomorrow night.
Vince
Offline Knox
« Reply #28 on: February 15, 2012, 08:11:16 AM »
diddo, I go to pick up my front ds today at Pats
and yeah 2 degrees below seems to be the standard suggestion
2003 TJ
