Author Topic: TJ Sub-woofer Replacement?  (Read 5853 times)
Offline Jrama
« on: February 20, 2012, 06:13:24 PM »
I blew the stock woofer in my TJ, any good place to find a replacement? To those who may not know a 6.5" shallow mount 2-ohm sub is not the easiest speaker to come across. Or better yet.....any easy-ish worthwhile upgrades? I have little experience with car stereos, but any suggestions that would point me in the right direction would be good.
« Last Edit: February 20, 2012, 06:16:21 PM by Jrama »
Offline BUKI
  • Project Fugly
Re: TJ Sub-woofer Replacement?
« Reply #1 on: February 20, 2012, 06:20:12 PM »
2 words tang band. You tube those. Ridiculous amounts of bass from those little cones. Only if you want something that will go in the stock location.  It would be an upgrade.
Offline BUKI
  • Project Fugly
« Reply #2 on: February 20, 2012, 06:21:49 PM »
Whichever way you go I can help out if you need
Offline X-Treme
« Reply #3 on: February 20, 2012, 10:20:57 PM »
Googled tang band, and they don't make a 2 ohm speaker.
« Reply #4 on: February 20, 2012, 10:36:29 PM »
Offline BUKI
  • Project Fugly
« Reply #5 on: February 21, 2012, 02:36:37 PM »
Well that sucks. I didn't think that it was 2 ohm
Offline Jrama
« Reply #6 on: February 21, 2012, 02:49:44 PM »
Yeah the eBay one was my top choice, I was just wondering if any other Wrangler owners got creative and found something local that works. Quadratec also has direct OEM replacement, but..meh
Offline BUKI
  • Project Fugly
« Reply #7 on: February 21, 2012, 03:09:30 PM »
Select increments had some cool stuff. But nothing that will fit in the stock location
« Last Edit: February 21, 2012, 03:14:31 PM by BUKI »
Offline 03Jeeper
« Reply #8 on: February 21, 2012, 04:10:58 PM »
I bought a replacement last year off ebay for a good price. It was made by Pyramid. Ill get the model number when i get home for you.
The sub is a cheap oem replacement, sounds good too.
Offline Jrama
« Reply #9 on: February 21, 2012, 04:27:36 PM »
Hmmmm....I just pulled the trigger on the ebay one......oh well,
 I'd think they'd sound about the same too, its not like the enclosure in the Jeep is any good.
Offline X-Treme
« Reply #10 on: February 21, 2012, 07:44:05 PM »
Did you go with the Kicker one? If so, I'd like to know how the install/fit goes, as well as the sound. Tia
Offline Jrama
« Reply #11 on: February 29, 2012, 05:19:19 PM »
I ordered the Kicker, as a matter of fact I ordered directly from the link posted earlier in this thread. And it Just arrived today!
I'll go install it and I'll let you know how it goes.
Offline X-Treme
« Reply #12 on: February 29, 2012, 09:44:51 PM »
Awesome!! Looking forward to your "review".
Offline Jrama
« Reply #13 on: February 29, 2012, 10:52:26 PM »
Well the install was actually pretty easy, the wiring was very easy and it sounds better than stock, Its not amazing but a definite improvement.
Hardest part was clearing out the housing to make room for the larger speaker. I took some tin snips and went to town, the plastic would just shatter when cut....sooo it was kind of fun.
Wiring involved attaching the brown wire to the negative terminal on the speaker and attaching the grey to the positive. I had to cut off the little clips on the wires, strip them and then attach them to the speaker. Speaker had these neat little clips so it was a breeze to hook it up. There were two wires (black,red) which I tried attaching..didn't work, left them unattached.
OEM Speaker still wired in
Kicker wired in
Drilled out some new holes for the original screws and after a few test fits it sat flush. Screwed back in, re-installed the center console and boom...new woofer.
« Last Edit: February 29, 2012, 11:01:17 PM by Jrama »
Offline Toyman
« Reply #14 on: March 01, 2012, 05:34:22 PM »
Thanks for the write up.  I was thinking of going this route myself, but I may end up doing a custom enclosure with a JL 8" of some sort, a 8W7 would be nice to fit in!
04 Rubi
