Author Topic: Driveline angles.  (Read 3958 times)
Re: Driveline angles.
« Reply #15 on: April 19, 2012, 07:07:30 PM »
No the TJ
Offline Labrat0013
« Reply #16 on: April 24, 2012, 08:13:47 PM »
So I installed my 1" motor mount lift. I now have the following angles with
Both the 1" mml and the 1" t-case drop.  Output 10* drive shaft 5* pinion 10*. So my next question is, do you recommend leaving everything as is or raise my t case to reduce the pinion/driveshaft and driveshaft/output angles and sacrface a bit of the output/pinion pairing? Keep in mind these angles are measured with a half tank. If i hook up my tent trailer with the current set up this would drop the rearn end making the drive shaft flatter and the pinion/drivesahft and driveshaft/output angles greater than 5*.
Any thoughts?
Cheers,
Cris
2000 TJ Sport, 2.5" OME HD, 31" BFG AT, 1" MML, Rubicon Sliders
